In-car, can unlock only driver side door?
w204 c230
We can unlock only driver door using the remote.
But while inside the car, when open driver door, can we NOT unlock other doors?
2009 C300 4Matic
there is a unlock button on the drivers door that will unlock all the doors...
and the remote itself should unlock all doors... if not with one push then try two.
i think this is what you were asking.
2002 S430, 2004 Cobra, 2004 Tahoe
Like said above, try pushing the unlock button once, then once again. Most likely your remote has been programmed to only unlock the driver door with one push. If you would like to have it open all the doors with one push, hold down the lock/unlock buttons together for 10 seconds and this will reprogram to open all doors.
w204 c230
w204 c230
When doors are locked, the whole door knobs/pins moved down and nothing sticked out for us to pull. Since we have the security feature to open only the driver's door with the remote control, for the same security reason, I wish the feature is available to only unlock the driver's door when we pull the inside door handle.
MBworld Guru
white and whiter
when the key is in the ignition when you pull the driver door handle only the driver door will unlock. all doors will unlock only when the key is out of ignition. if that's what you are asking.
you can change the program on the key by holding the lock+unlock at the same time for 10sec or so till the light on the key flashes. It toggles the mode between unlocking driver's door only and unlocking all doors on first click. if this is what you are asking.
Thanks!
w204 c230
You mean you can toggle this feature back and forward by holding down the two buttons?
