how to take off the shark fin antenna?
I've seen fake covers that could cover the antenna after your wrap job but don't know what this would do to the GPS / radio signals....
Good luck!
The only way to remove the antenna is to remove the headliner. I know it's not what you want to hear but it's the only way.
Remove the light in the rear with the MB specialty tool (MasterCard in this case) just push in up and in from the front. Move it left or right and pull down gently. Unplug it. Now the macguyver stuff starts. I forget if it's a torx head or an Allen. Either way, I had a socket with that on it. Held it in place with two fingers and a small vice grip plier on the base of the socket. About two turns (8th of a turn at a time with the vice grip) and it was finger loose. Once you get the bolt removed, it is still attached by the wires which you will not get removed with out removing the headliner. I imagine if you loosened it about 4 or 5 turns it would suffice for the installer. Just do it on site, don't drive down the road with it loose, it won't be there when you arrive!
The color keyed fin comes with a certain package or something. However I don't think I've seen a C class that had the sharkfin match the body.
Good luck and have fun.
