08 220 cdi w204 key not working HELP needed
Subscribe
Apr 27, 2014 | 05:40 PM
car is bricked, key wont open the doors when i tried this morning so i opened with the valet key, key in the ignition and nothing no lights on the dash key just turns nothing else? any ideas before i get it towed away and get raped by the dealer
any help appreciated? i'm stumped?
Reply 0
Apr 27, 2014 | 07:20 PM
Quote: car is bricked, key wont open the doors when i tried this morning so i opened with the valet key, key in the ignition and nothing no lights on the dash key just turns nothing else? any ideas before i get it towed away and get raped by the dealer
I would check the battery voltage first (multimeter across the terminals).& then ascertain why it went flat.
The battery is nearly 6 years old & may need replacing.
Did you leave any electrical equipment on ? .
Careful when jumpstarting . Make sure your key is removed from ignition before attaching the jumper leads. SAMs can be damaged by voltage spikes.
If you have to replace the battery make sure it is of the correct amperage & of the AGM (Absorbed Glass Matt type.
Good luck.
Reply 0
Apr 29, 2014 | 03:19 AM
Do you have those 4 wheels turning again Indo ?.
Reply 0
Apr 29, 2014 | 03:36 AM
Same thing happened to me, it is most likely the battery. Try jump starting your car before deciding to tow it to the dealership.
My headlight switch was malfunctioning and it often left my passenger side eyelid bulbs on. When I returned to my car after 4 days, it would not respond at all, but lucky for me, MB roadside replaced the battery under warranty.
Besides taking your key out of the ignition, also make sure to remove the car's battery terminals before jumping it, that's exactly what MB roadside did for me. (Probably to avoid damaging any of the electrical parts of the car like the SAM module)
Reply 0
Apr 29, 2014 | 05:47 AM
Quote: Same thing happened to me, it is most likely the battery. Try jump starting your car before deciding to tow it to the dealership.
I am interested to learn in detail about MB Roadsides method of removing cars terminals before jumpstarting ?
Reply 0
Apr 29, 2014 | 11:30 PM
Remove the black air circulation cover part located on the bottom of the windshield of your driver side (assuming you are right hand drive).
Then undo the 3 clips holding the black part in place.
After removing the black cover, get a wrench and unplug the car from the battery completely.
After the terminals are removed from the battery, jump the battery and let it charge for a bit.
After charging the battery briefly, you should be able to start the car again, but the battery will probably need to be replaced or trickle charged, depending on the condition of the battery.
Refer to post #5 of the following link. http://www.mbclub.co.uk/forums/elect...ight-w204.html
Reply 0
Apr 30, 2014 | 01:39 AM
I am having difficulty understanding the difference between your method of recharging the battery with the terminals removed then reattaching them with the battery fully charged.
To me it will make no difference to initially attach the live jumper leads to a flat battery .
Both methods will result in an initial voltage surge .
I am positive my car does not have 2 batteries.
John.
Reply 0
Subscribe
Currently Active Users (1)
