A/C buttons peeling
Old 05-05-2014, 09:41 AM
Junk151's Avatar
2008 C300 Sport
A/C buttons peeling
Has anybody had to deal with this? The buttons for my a/c controls and the steering wheel controls are peeling. Not sure how this could be fix other than replacing them.
Old 05-05-2014, 09:55 AM
Clkboi's Avatar
CLS550 4Matic
Damnn everything is peeling on these cars wtf...
Old 05-05-2014, 02:34 PM
c350nubie's Avatar
'08 C350 Sport
All these peeling crap are covered under factory warranty. I assume you are not in factory warranty as your car is 2008? They won't fix it under extended warranty I already tried. You can try to talk your dealer into fixing. If not, plasti dip may be?
Old 05-05-2014, 03:43 PM
Project C's Avatar
MB C250
why is all these peeling issue happen?
mine is armrest plastic area
thinking to wrap 3M or just change CF which is much $$$
Old 05-05-2014, 04:09 PM
Junk151's Avatar
2008 C300 Sport
I just saw the other threads about peeling issues. Not very Mercedes like and yes, I'm not under warranty anymore.
Old 05-06-2014, 11:34 AM
MDMercedesGuy's Avatar
2024 GLS450
Do you use lotion or anything on your hands? Was the car pre-owned when you got it/could someone else have done this?
The manual calls out that some skincare products can cause this. It's not unique to Mercedes, either.
Old 05-06-2014, 11:40 AM
Junk151's Avatar
2008 C300 Sport
Don't use anything on my hands and I'm the second owner of the car but this just started happening. The buttons were fine when I got it and remained fine for the last 2 years until recently. The "OK" button on the steering wheel is starting to do the same.
Old 05-06-2014, 12:10 PM
oaybar007's Avatar
2011 C300 Sport 4Matic, 2004 Audi A4 1.8T Quattro Ultrasport, 2010 Subaru Forester
True. My 2004 Audi is a peeling mess. Buttons, switches, you name it on the interior, it is peeling. It was a manufacturing oversight in materials. They used a rubberized finish that was nice to touch but wore off with time. They fixed it on later models.
I've seen many cars with peeling problems and I can only imagine that the manufacturers of those items are to blame in what materials they've used. They don't stand up to UV, skincare, certain cleaning products or the reverse can be true...if they are not cleaned often enough maybe the plastic can dry out...it's a strange problem and annoying!
If you use a moisturizer or anything that leaves a residue on your hands that can rub off onto the buttons, depending on the formulation of the product it could break down the button material. I think that's a rare case and the cars should be designed better regardless. It shouldn't be an excuse for the company to note to owners. Short of using nail polish remover on your buttons, these things should be designed to deal with it.
Old 05-06-2014, 12:21 PM
oaybar007's Avatar
Can anyone with peeling buttons post pics?
Old 05-06-2014, 12:34 PM
Junk151's Avatar
2008 C300 Sport
I'll post some pictures when I get home.
Old 05-06-2014, 06:43 PM
sev7nflow's Avatar
2013 C250 Sport
The aluminum trim seems to be peeling off on my steering wheel. Does anyone know if this is covered by the factory warranty? I bought this car 2013 CPO and its been bothering the hell out of me.
Pics attached of the damage... seesm to be slowly getting worse
A/C buttons peeling-20140506_063147.jpg
Old 05-06-2014, 10:15 PM
2024 GLS450
All of these issues are not normal wear and tear and should be covered by the factory warranty.
Old 05-06-2014, 10:20 PM
Junk151's Avatar
2008 C300 Sport
Here's mine:
Old 05-07-2014, 10:19 AM
oaybar007's Avatar
Having been through this before with another manufacturer. Here's exactly what I would try to do. No guarantee this would work, but this is very unlike MB in quality as far as I can see.
If you are under warranty of any kind, try to get it covered at a dealer. At least have them look at your car and confirm your buttons are peeling. Get info from the service team, name of manager, number, etc.
If you're out of warranty or they're not covering it, go to MBUSA directly and let them know the problem. Mail them photos and be detailed. Tell them that you want all of your buttons replaced. They need to know what you want from them to try to help you. Just complaining doesn't really work. Tell them you want all buttons replaced by the dealer where it was examined, and give them the service managers info.
Also note that you will follow up with both the service manager and MBUSA in a certain period of time if you don't hear back.
If there's no response, the next step is to create an official peeling button thread and everyone with the issue post pics to document and point MBUSA there in your follow up.
At the very least, If out of warranty, I would try asking for a credit on anything I buy from MB moving forward. Quality issues like this lose customers, sadly. It's not our fault as customers and at the least, they should give you some credit on another Benz purchase.
In terms of a fix on your own. Maybe you can source buttons from salvage cars or find spare buttons elsewhere. I don't think painting them will help
Old 05-07-2014, 11:07 AM
Henry320's Avatar
2013 c300
This is not normal, it should be fixed under warranty
Old 05-07-2014, 11:12 AM
Andriy242's Avatar
14' E63S
That definitely is not normal...unless you have hands as rough as steel and nail the size of scissors and keep picking at it every day...thennnnnnnn that won't be covered under warranty!
Old 05-07-2014, 12:40 PM
djhurayt's Avatar
08 C350
My buttons are peepling as shown also and the chrome strips along the door are doing the same things H320's sterring wheel chrome.
This car is my first & LAST benz, the quality sucks
Old 05-07-2014, 02:30 PM
sev7nflow's Avatar
2013 C250 Sport
Quick update: Got in contact with a service manager and they will be fixing the issue
Old 07-28-2015, 02:20 PM
JorgeM's Avatar
2012 c220 coupe
Did they fix the problem with the aluminum on the steering wheel? My car is having the same problem, the aluminum is so sharp that sliced my finger when I was cleaning the dashboard, now the buttons are peeling off.
<a href="http://s24.photobucket.com/user/jorgerolito2/media/image1_zpslljnddt0.jpg.html" target="_blank"><img src="http://i24.photobucket.com/albums/c49/jorgerolito2/image1_zpslljnddt0.jpg" border="0" alt="Buttons peeling off mercedes photo image1_zpslljnddt0.jpg"/></a>
Old 07-28-2015, 03:08 PM
tekfoc's Avatar
18 E63S
the warranty will cover it . run and get it done .
Old 07-29-2015, 10:35 AM
Antique-Ace's Avatar
2014 CLS550-4M, 2013 C350-4M Coupe
BMW's have the same problem. My HVAC controls were peeling in my (F10) '11 550ix after about 25K miles. It was fixed under warranty.
Fortunately, no peeling (so far) in my '13 C350 coupe.
Old 06-02-2016, 09:40 AM
JorgeM's Avatar
2012 c220 coupe
The warranty won't cover that unless you have extended warranty, I have a mercedes 250- 2012 that has the same problem you are having. I'm at the mercedes dealer right now and replacing that fake aluminum accent will cost you $105 plus labor.
Old 06-02-2016, 09:46 AM
JorgeM's Avatar
2012 c220 coupe
I'm at the mercedes dealer and the two sets of buttons will cost me $165 each plus labor.
Old 06-02-2016, 09:47 AM
JorgeM's Avatar
2012 c220 coupe
The warranty won't cover that unless you have extended warranty, I have a mercedes 250-2012 that has the same problem you are having. I'm at the mercedes dealer right now and replacing that fake aluminum accent will cost you $105 plus labor.
Old 06-02-2016, 10:01 AM
michail71's Avatar
2013 C250 Sport
You can purchase both control buttons from ebay for about the price of one and DIY. It just requires a T-20 screw driver and a pick of some sort to release the pressure fittings.
Quick Reply: A/C buttons peeling
