Dedicated Power Source for Tablet?
Old Jun 23, 2014 | 06:53 PM
glj12's Avatar
C300 Sport
Question Dedicated Power Source for Tablet?
Hi all,
I realized that this has been answered in the past, but I have gotten a bit of mixed information.
If I want a dedicated power source for my tablet, what would I tap into? I see no fuse boxes in the front of my vehicle, only in my trunk. Where or how would I get a power source that can supply 2.1A at 10W for my Nexus 7 tablet?
Any pictures would be useful as well.
Old Jun 24, 2014 | 08:28 AM
lyndonl's Avatar
C200 W204
I use a dual port 12v usb adaptor in the back lighter socket,
I can't recall the make, but it was a 12v 1.2 Amp adaptor, although you mayn't want to use one of these the rating info should help
Old Jun 24, 2014 | 09:22 AM
glj12's Avatar
C300 Sport
I didn't think that any lighter sockets were unswitched and constantly giving power even when the car is off. What are you referring to?
Old Jun 25, 2014 | 09:11 AM
glj12's Avatar
C300 Sport
Bump. Does anyone have a solution for a constantly on power source that is not in the trunk?
Old Jun 25, 2014 | 09:58 AM
Drazil's Avatar
There should be a fuse you can change to set the lighter socket to always on even when the engine is off. I did it on my w211. It's one of those fuse sockets that have 3 holes, and you move the fuse over to the alternate seating.
Old Jun 25, 2014 | 01:13 PM
aznmode's Avatar
2010 c300
Originally Posted by glj12
Hi all,
My friend installed a nexus 7 first gen on his wrx but was using a cheap 1amp charger so his tablet always ran out of battery. Had him switch it to a 2.1amp charger and he hasn't it lose power since. Even with gps and data running simultaneously.
Old Jun 25, 2014 | 01:37 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
An option would be to install a power inverter that is connected to a constant 12v source. The bad thing is that it will probably drain your battery while using your tablet with the engine turned off. I would only use a switched 12v source to prevent draining the battery.
Old Jun 25, 2014 | 01:59 PM
glj12's Avatar
C300 Sport
Maybe I'll look into that. I thought that my DC inverter was rated at 2.1. My problem has been that I don't drive my car long enough to make up for the 4-6% battery loss over night and the time that it sits at work.
As per the 3 hole fuse and making it constant power, I don't recall ever seeing that, but I'll take a look at it this evening.
As per draining the battery of the vehicle, I appreciate the concern, but I think I have this covered. I can control when the tablet charges, so I will have it charge up to 100%, stop, and wait a few days, then start charging up to 100% again (scheduled charging). Therefore, it would never drain my battery.
Any other thoughts, guys? If the 3 hole fuse option does not work, what else am I left with?
Edit: capt_paul: What 12V source are you talking about that's always on? That's my problem in this thread: where is it, other than the trunk?
Old Jun 25, 2014 | 05:23 PM
glj12's Avatar
C300 Sport
Unfortunately, none of my fuses have 3 holes as you described to put it in a constant power state. All of my fuses have two holes for each prong.
Does anyone else know where I might be able to tap into a dedicated, always on, power source in the front cabin?
Old Jun 26, 2014 | 01:40 AM
Doanster's Avatar
C300 Sport 6MT
If you must have a constant supply, why not just tap directly into the battery as if you were going to install an amp? Short and sweet since you're not running the cable all the way back to the trunk.
Are you permanently installing/integrating the tablet (which one, btw?) into the dash so that you can't remove it? Otherwise, why not just charge it overnight inside the house? Leaving it in the car throughout the day/night would be too attractive for thieves IMO. Also, as tablets these days have very fast boot times, I'd power it down when you arrive at work (not just put it to sleep/turn the screen off by short-pressing the pwr button).
Old Jun 26, 2014 | 08:40 AM
glj12's Avatar
C300 Sport
I wanted to try and avoid tapping directly to the battery. It would be nice if there was something I could tap into without reaching that far, and under the hood.
This is a permanent install. I'm not too concerned about theft.
I have been turning it off/on each time the car turns off, all controlled by the key in the ignition. Maybe I'm just a bit impatient, but a full minute to start up (from boot to playing Pandora) is a bit too long for me. I would prefer an instant-on solution.
I'm using the Nexus 7 (2013) tablet, by the way.
Old Jun 26, 2014 | 07:30 PM
glj12's Avatar
C300 Sport
Question
And where would I find this 12v power source you are talking about? The only one mentioned so far is a direct line to the car's battery, which I do not want to touch.
Old Jun 29, 2014 | 11:22 AM
glj12's Avatar
C300 Sport
Since this thread is probably dead, I'll share my final solution. I ordered a 1500mAh battery that will charge my tablet and be charged while driving. I figure the portable battery will be easier for me to remove and will maybe need to be charged every 2-3 weeks or so. I might do some charging regulation with my tablet as well, and have it pull from the battery for a full charge every time it reaches 50%.
