My w204 strut tower bolt is stripped
Old Jul 15, 2014 | 02:08 PM
jonson10's Avatar
c200
Thumbs down My w204 strut tower bolt is stripped
My strut tower bolt was stripped by my mechanic when installing new suspension... and now, I would like to remove my top strut brace... and found the bolt is stripped...I am really sad... my car is brand new......what can I do to remove it..
And I would also like to order a new bolt... where can I find a new one?
Many thanks
Old Jul 15, 2014 | 03:43 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Many thanks
you can order it from a number of wholesale online dealer parts departments. You don't say where you live, so it is hard to answer your question more precisely. If you need the part number, simply register for free access to Mercedes EPC (Electronic Parts Catalog). Then input your VIN and go under suspension and find the part. Then order the part from one of the online sources or go to a local dealership.
Old Jul 15, 2014 | 03:45 PM
capt_paul's Avatar
I also highly suggest that you retap the bolt hole in the strut.
Old Jul 15, 2014 | 04:27 PM
jonson10's Avatar
c200
Thanks for your information, I live in Hong Kong, I just found out the part number through EPC and will try to order through dealer tomorrow.
Just one thing making me confused, what do you mean by retaping the bolt hold in the strut? Would you mind clarifying a bit more? thanks bro
Old Jul 15, 2014 | 04:33 PM
jonson10's Avatar
c200
the part number should be
A0029904503
Old Jul 16, 2014 | 08:25 AM
jonson10's Avatar
c200
bump....
Old Jul 16, 2014 | 06:06 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
This is what he means by tapping the bolt hole:
http://www.wikihow.com/Use-a-Tap
basically just fixing the screw thread.
Old Jul 17, 2014 | 01:26 AM
capt_paul's Avatar
If you put a new bolt in a damaged thread in the strut, it may damage the new bolt. Re-tapping the thread will clean up any imperfection that may have caused the stripped bolt in the first place.
