Jack point broke off?!?!
WTF? Has anyone ever heard of this happening before?
I was in a parking lot, on level ground.
I'm sure I'm screwed as far as warranty is concerned, but these things seem a bit flimsy as it is.
I contacted MBUSA and they told me that it might be under warranty, but there are certain exclusions, and that I would need to go to the dealership to have the service manager determine if it is under warranty. Basically said that service manager's word will be taken as fact, so I'm hoping our service manager will be on my side! I'll update after I take it in.
If the car had been jacked up properly, then the forces that are in play are vertical -i.e. the weight of the car loading down on the jack... A wild guess is that in this case, the car rolled in one direction or another at which point, the jack swung up and out from underneath it and dented the door!
You didn't mention this but which wheel was it you were changing? And more importantly, which wheel did you have choked off?
Jksooner,
I highly doubt this will be covered under the Mercedes warranty but your automobile insurance policy should take care of it... Less your deductible!
The tire I was changing was the driver's front... I had the passenger rear chocked. Here's the confusing part: The manual says to use the chocks, if so equipped, and then says to chock the front and back of the tire. My car is only "so equipped" with one chock, not 2. Since I was jacking the front of the vehicle, I chocked the rear of the opposite rear tire, as per the instructions... assuming that if I was jacking the front, movement would more likely be backwards than forwards. Anywho... My kit doesn't even have a space for a second chock, so not sure how I could have chocked the front of the tire anyway.
But isn't it odd that the manual would show you how to chock, but some cars are not equipped with the chocks??? I dunno... first time I have ever used the jack on this car, and I've never had another vehicle that came with a wheel chock. Nice to have, but not sure it really helped me. I dunno. Just glad it didn't do more damaged (i.e. brake caliper, rotor, etc.).
And I don't want to claim it on my insurance because they like to bump my premiums for ANY claim. Suck.
