Old Jun 9, 2015, 12:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Drivers Power Lock
Old Dec 30, 2014 | 01:57 PM
hammer2514's Avatar
2010 C300
Drivers Power Lock
Hi, I am having an issue with the power door lock on the drivers side. Intermittently with the key fob the drivers door will not lock or unlock. It appears just to be lazy. The lights and sounds come on when lock/ unlock attempts are tried and the other doors work fine. This also occurs with the door lock/ unlock buttons on the door panel. I have changed the batteries on both fob's and lubricated the door latch. The door will lock and unlock with the steel back up key that is in the fob. I do not have the keyless go feature. Any thought?
Old Dec 30, 2014 | 04:16 PM
awstansbury's Avatar
2018 C300 sedan, P1, Multimedia, Burmester
Is your car still under warranty? This happened to my 2009 C300 and it turned out the door lock actuator was bad.
Old Dec 30, 2014 | 10:43 PM
dudeitsmattx's Avatar
2013 C250 Sport
Yup sounds like a bad actuator like he said
Old Dec 31, 2014 | 06:54 AM
hammer2514's Avatar
2010 C300
I'm leaning towards the actuator also. There is a low buzzing type noise from the actuator when it does not work. I'm thinking that its only a matter of time when it does not work at all. I will see what the dealership wants for the part. Maybe I can find one online.
Old Dec 31, 2014 | 08:26 AM
lacoa1's Avatar
09' C300 Sport 4Matic
If you can consistently replicate the problem I would pull the panel and check from there, could just be something hanging up which will also cause the buzz with no action. There doesn't appear to be any aftermarket for the lock actuator but i believe the mb part number is 204 720 13 35.
Old Jan 1, 2015 | 07:08 PM
hammer2514's Avatar
2010 C300
Looks like its the actuator. It does not work at all now. Any idea how to remove the aluminum cover that is behind the door panel. I see some rivets there that probably need to be drilled out. There is no DIY for a door actuator replacement.
Old Jan 1, 2015 | 10:45 PM
lacoa1's Avatar
Yep, time to drill some rivets. I believe on this model the exterior handle assembly may have to come out also but that is secured inside the panel also. Labor time for this one calls for 1.4 hrs. Don't be discouraged if it takes significantly longer. Any questions just ask, I have Mitchell pro demand so I can pull up the schematics and procedures if needed. At least it's a clean job! Could be worse!
Old Jan 2, 2015 | 09:50 AM
hammer2514's Avatar
2010 C300
Yes, I had the door panel off. It is pretty clean work. Shouldn't be too difficult but I wouldn't mind having the step by step procedure. Is there any way you can send me them? I can never be too sure!
