Old Jun 9, 2015, 12:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Door lock not work
Old Dec 30, 2014 | 02:55 PM
Kulin's Avatar
C-Class W204 320 CDI
Door lock not work
Hello.
I'm new member, hello for everyone.
I have big problem. In my one door (front door passenger side) door lock not work. I removed door panel, but I don't now how removed metal panel, I removed the rivets but can't draw metal panel with glass.
Please help me.
Thanks.
Kulin
ps. sorry for my english
Attached Thumbnails Door lock not work-img_0995.jpg   Door lock not work-img_0996.jpg
Old Dec 30, 2014 | 10:42 PM
dudeitsmattx's Avatar
2013 C250 Sport
Sounds like a bad actuator
Old Dec 31, 2014 | 12:52 AM
Kulin's Avatar
Yes, you have write. I must change acuator, but I can't remove the aluminum cover
Old Dec 31, 2014 | 12:02 PM
hammer2514's Avatar
2010 C300
i am experiencing same problem on the left front door. I think its the actuator also. How did you come to your conclusion of a faulty actuator?
Old Jan 1, 2015 | 11:49 AM
Kulin's Avatar
At the beginning of the actuator sometimes closed and opened door, then completely stopped working. Thus, it seemed to me that the actuator, not control.
Now I know how to replace it
Old Jan 1, 2015 | 07:05 PM
hammer2514's Avatar
2010 C300
Mine has done the same thing. First it was intermittent, now it does not work at all. Looks like I will have to replace mine also. Looking at your pictures, once I remove the door panel (which I have already done before to check if actuator was binding) I assume you have to drill out the rivets to remove the aluminum plate, then remove the actuator. Is this the procedure you followed. Any help would be appreciated.
Old Jan 2, 2015 | 01:50 AM
Kulin's Avatar
Today I'll prepare few pictures...
Old Jan 5, 2015 | 03:49 PM
Kulin's Avatar
Please look to my instruction.
Sorry but this is polish version, if necessary I'll prepare englisg version
Old Jan 5, 2015 | 05:06 PM
hammer2514's Avatar
2010 C300
thanks brother, I will translate with google and attempt this week. I will let you know how I made out!
Old Jan 6, 2015 | 03:37 AM
Kulin's Avatar
OK. This isn't difficult. If You something don't know, write to me.
Good Luck !!
Kulin
