Front..... W211 E350 4piston caliper
Rear....R230 SL500 2piston caliper
This calipers can be fit to the my W204 C350(2009) ???
It would be trial and error, the E350 has a 330mm disc with a 64.9mm hat, the C has a 64.5mm hat... So the 4pot setup with the 330mm rotor may work
Quote:
Do you mean disk offset?
Processing the caliper or change the disk?
Are these W211 E350 calipers from 2006 model..?
ZAYED,,
ZAYED,,
yes disc offset. I believe the 09 c350 use a 322mm rotor, so you would also need the 330mm rotor to use with this caliper you have pictured.Originally Posted by Scoop SJ
Do you mean disk offset?Processing the caliper or change the disk?
Quote:
size between the caliper holes and the knuckle holes the same? Originally Posted by silverjimm
Currently Active Users (1)
