Upgraded to 19s, is my spare tire still ok to use?
Subscribe
Mar 9, 2015 | 07:14 PM
I've upgraded to 19s but with 235/35F and 265/30R tires so it's slightly bigger in diameter now. Will my spare tire still be ok to use for the rears?
Reply 0
Mar 9, 2015 | 07:27 PM
Want to know as well....
Reply 0
Mar 9, 2015 | 08:47 PM
As long as your overall diameter of wheel+tire is the same then you should be fine.
Reply 0
Mar 9, 2015 | 09:03 PM
Quote: As long as your overall diameter of wheel+tire is the same then you should be fine.
It's not that's why I asked. The closest tire size to match stock is 225/35F and 255/30R. But those tires would've had a slightly stretched looked so I opted for more rubber. But I'm not sure if the small difference would cause any issue. Specifically for the rears.
Reply 0
Mar 9, 2015 | 10:28 PM
If you have 4 matic then technically the answer is no
You'll over wear your differential
Reply 0
Mar 9, 2015 | 10:54 PM
I would suggest you only use the spare on the non drive axle side (i.e. use on front for rwd and rear on fwd). I would also assume you'd run into trouble with stability and traction control. I've heard that there's a small tolerance for diameter difference like no more than 1/4th to 1/2 an inch but I could be wrong and wouldn't bet on it unless someone else can confirm.
Reply 0
Mar 9, 2015 | 10:58 PM
If you increased your rim size by 1 inch and dropped your tire size down 1 side wall height that would be the same rolling diameter. The width does not matter.
Reply 0
Mar 10, 2015 | 04:30 PM
If he were using it to commute daily I'd worry. (I know some idiots that leave spares on for weeks and months.) If you use a spare correctly for the time it takes to get to a shop I doubt you have much to worry about in terms of excess wear.
Reply 0
Explore
Subscribe
Currently Active Users (1)
