w204 c200 Blueefficiency
Old Apr 25, 2015 | 10:43 AM
bothered's Avatar
mercedes c200 blue efficiency 2011
Had diff. sensor changed & dpf cleaner into dpf sprayed.
However engine light reappeared soon again.
Mechanic not sure what to do.
Fault code P244A7A
Help please. Any expert out there?.
Old Apr 25, 2015 | 01:24 PM
bothered's Avatar
[QUOTE=bothered;6412200]Had diff. sensor changed & dpf cleaner into dpf sprayed.
Fault code P244A7A
Old Apr 27, 2015 | 11:57 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W204 forum...
Old Apr 27, 2015 | 04:50 PM
bothered's Avatar
w204 blueefficiency
Dear MJ50,
Greetings from Ireland.
Thank you for your prompt reply. However for some unknown reason it failed to make it across the Atlantic or so it seem.!!
If you get a chance perhaps you might resend it.
This is my second Mercedes. The first was also c-class, petrol - an alcoholic!.
Mercedes is very comfortable but can be temperamental at times.
Looking forward to your solution.
Regards,
Sean (bothered)
Old Apr 28, 2015 | 02:17 AM
Knightmare69's Avatar
2010 C200 CGI
This is what I got from your fault code, if this is the case then I'm not sure why you were changing the sensor in the differential. You guys are working at the wrong end of the car.
Trouble Code:
System:
Subsystem:
P2447 - (ASE)
Powertrain
Auxiliary Emission Controls
DTC Description: Secondary Air Injection System Pump Stuck Off (Bank 2)
Old Apr 28, 2015 | 05:45 AM
bothered's Avatar
w204 blueefficiency
Hi,
Thanks for your reply.
I will pass on your suggestion & will relay results.
Regards
Sean (bothered)
Old Sep 14, 2021 | 07:47 AM
Paul 59's Avatar
C220 executive cdi
Hi,did you get this problem sorted out as I have exactly the same problem any advice welcome as I'm running out of ideas
many thanks in advance
Paul
