Oil shooting out of oil filter after oil change
I'm using this filter: http://www.oreillyauto.com/site/c/de...ord=oil+filter
Is this as simple as purchasing an OEM filter or is it something else?
Did you replace the 3-4 rings supplied with the new filter?
Also be aware, as it seems that the filter in your link is not made of fleece. Because of that, it does not meet MB's specifications for extended oil changes of 1 year / 19K miles when using a 229.5 approved oil AND the fleece oil filter. For the 7 quarts or so of oil you put in there, I'd recommend going with the filter from your MB dealer instead, as that's expensive oil to be replacing more often than you need to.
19k for an oil change? I've been doing it every 10,000 and my C300 takes 9.51 quarts of oil according to the owners manual. Is that 19k with a fleece filter typical?
I apologize - being from Canada, I confused miles and km. When I first bought my car, my dealer said oil changes are every year or 19,000 KILOMETERS. This seemed incredibly high at the time, as I was used to 2-3 oil changes a year ever 5-6,000 kilometers. They told me it's because of the filters that MB uses. For that reason, if you are not using the fleece filter with the approved 229.5 engine oil, you shouldn't be getting anything close to 10,000 miles per oil change.
I hope that helps.
