RADO front mounted intercooler installed, with RADO full exhaust
Question though. What's the benefit of upgrading the FMIC when the stock turbo barely flows enough air to push the capacity of the stock FMIC? Does the exhaust help the turbo not drop off so bad on the top end? Seems like these upgrades may be cosmetic at best with such a poor performing stock turbo. I've heard that even with a stronger waste gate the turbo still doesn't hold boost at high rpm. Boost creep from a free flowing exhaust would probably be helpful if the turbo could keep up.
Also, whats the bolt pattern on the turbine to downpipe? Is it a V-clamp? Nice to see someone actually doing some upgrades to the 250 that are at least performance oriented. Nice platform and chassis, shame it makes so little power.
Just wish I knew exactly what turbo is on the car so I can investigate some stock based turbo upgrades. What do you have the BMS tuner set to? Any overboost issues?
Then I cross referenced it with some units for sale. There are a few on Ebay. Also this site has listed most of the applications.
http://shop.turbocentras.com/en/turb...er-al0065.html
It is actually listed as an IHI/Borg Warner turbo. The part number on the heatshield I initially though was also for the turbo, but they are different.
http://www.ebay.com/itm/Mercedes-Benz-204-C-Class-271-Engine-Turbocharger-Brand-New-OEM-271-090-36-80-/151574643058?hash=item234a8d8172&vxp=mtr
It seem IHI and Borg Warner made some turbo together, I am not 100% sure if this is one. It was listed for use on the E Class Blu Efficiency. Think that is a Diesel?
I come from the Mitsubishi/Honda turbo world where tuning options are abundant. Piggyback systems that offer almost limitless adjustment to fuel, timing, throttle parameters, and more with just a laptop. Renntech offers some nice options, but not for the the C250. I found info on the CLA45 turbocharger. It looks like it could work with a proper manifold and some modifications to the charge pipe outlet. The oil feed and water lines look similar. The turbine outlet to the down pipe is 3 bolts like the C250 unit.
Of course to see if this is even an option, we would need measurements of the manifold port spacing and size. It would be mounted facing down on the C250 rater than top mounted on the CLA45.
http://www.mboemparts.com/mercedes-b...e=turbocharger
Questions about the downpipe. Any issues with CELs after the install?
