Cylinder Bank 1 and Bank 2 TOO RICH?
Old Oct 15, 2015 | 09:24 AM
MBstve's Avatar
Mercedes-Benz C Class
Kindly take time to read and help me.
My car is a 2009 C350
I have the check engine light on for a while now.
Have had it reset many times but it still comes back.
The car still seems to run normal, engine temp I think is still almost the same as before. I had my MAF Sensor cleaned using "CRC MAF Sensor Cleaner" few months back, past mechanic "said" he is sure that he installed the MAF sensor back into the car properly.
The computer diagnosis says that:
0746 The Mixture (Cylinder Bank 1) is TOO RICH current and stored.
0750 The Mixture (Cylinder Bank 2) is TOO RICH current and stored.
What does this exactly mean???
Symptoms:
a. Check engine light is on.
b. A "humming/whooshing" sound can be heard INSIDE the car (particularly the front left side) its loud but not very loud. This happens when I'm slowly accelerating from 0-25mph, the sound is also there while I'm "COASTING" (foot off the accelerator) at those speeds. If the car is on PARK, and I press the accelerator, the sound can also be heard, but its not as loud as when the car is moving.
I went to 2 shops:
1. The first repair shop I went to, they said that they are positive my catalytic converters have problems and needs to be changed. (This is a very very expensive repair, and parts are not available yet), they said that the broken ceramics inside the catalytic converters are making the humming/whooshing sound and also causing the check engine light at the same time.
2. Yesterday, I went to the second repair shop for a second opinion, they said that the "Humming/whooshing sound" and the "Check Engine Light" is not related. This means that I have 2 different problems with my car! They asked me to leave the car next week so that they can check for "air leaks or bearing problems" and also check the "catalytic converters"
The shops already charges money just by finding what the problem is. This means that they can check all they want with the car, even on "unrelated parts" and charge everything to me. Hopefully they'd be honest.
On the other hand, if the catalytic converters are really the problem, then they are also freaking expensive to replace for an old car.(is it possible to just totally remove the cats and bypass the check engine light by doing an ecu reflash? cause someone told me this might be possible.)
and lastly, I definitely don't wanna waste my money by changing a wrong part that is not actually causing the check engine light and the humming sound problem.
So what does "The mixture (Cylinder Bank 1 and Cylinder Bank 2) is TOO RICH" exactly pertain to? Pls. help.
Has anyone encountered this problem?
Thanks.
Old Oct 15, 2015 | 11:31 AM
tekfoc's Avatar
Veteran: Army
18 E63S
bad oxygen sensors. up stream sensors
if cats were bad down stream oxygen sensors is suppose to set off a check engine light with a non efficient cat operation.
read below how to test for exhaust pressure
http://www.tuneruniversity.com/blog/...aust-upgrades/
Old Oct 15, 2015 | 05:28 PM
tekfoc's Avatar
Veteran: Army
18 E63S
also have your mass air flow sensor retested and your fuel pressure regulator tested
Old Oct 16, 2015 | 10:18 AM
MBstve's Avatar
Ok, thanks, I'll have them check these parts first before anything else.
We'll see, hopefully its not the whole catalytic converters
Old Aug 15, 2016 | 11:08 AM
pttk's Avatar
magLipVE
Is OK this error?
I have The same car with same error, I chance lanmba sonda, but error persite.
https://mbworld.org/forums/c-class-w204/634654-c350-error-0746-0750-a.html
Any idea?
Old Aug 15, 2016 | 11:29 AM
CGC's Avatar
CGC
2009 C350
^This.
Old Aug 15, 2016 | 11:33 AM
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
Originally Posted by CGC
^This.
+1
Old Aug 15, 2016 | 11:42 AM
pttk's Avatar
magLipVE
Error C350
Originally Posted by Josh.A.Hussey
+1
Ok, but is no easy this procedure, I think need very specialistyc mecanic!!.
Thank
Old Aug 15, 2016 | 12:25 PM
twowheelin's Avatar
2014 C250
I've dealt with a couple of V6 engines with cat converter problems and this sounds very similar. The cat's should be covered up to 80K miles under the emission system warranty. The 'wooshing' sound is typical for a plugged up cat and is more prevalent when the engine is under load. MB exhaust system is similar to others with 2 stage catalytics so it would appear your first cats are the issue. replacement cats are available, but you'll have to remove and cut up the entire system to replace the cats. It will probably be cheaper to get a new exhaust system. On-line costs look to be $950 or so. Labor should be 2-3 hundred.
Old Nov 5, 2018 | 11:47 PM
Yunusa 1980's Avatar
C300 4matic sport 2011
Error code in c300
Can anyone help! How can I resolve this error codes
Old Nov 5, 2018 | 11:49 PM
Have u resolve the problems and if yes how?
Old Nov 6, 2018 | 05:21 AM
tekfoc's Avatar
Veteran: Army
18 E63S
could be bad upper stream oxygen sensor or dirty sticking fuel injectors.
Old Nov 19, 2019 | 11:30 AM
ralph naffaa's Avatar
c300 2009
W204
Hi dear i have the issue in my w204 c300
did you solve the problem of yes please let me know thank youu
Old Mar 5, 2020 | 11:54 AM
arikgo's Avatar
mercedes c280
hi an old tread but did any of you solved the problem?
i have the same problem...
Old Apr 29, 2020 | 07:11 PM
Maxweisen's Avatar
2009 C350, 2003 ML500
I also have codes 0746, 0750, 0292 and 0296.
These came on almost immediately after getting the A/C refrigerant refilled. Not sure if that could be related.
Old Apr 30, 2020 | 02:15 AM
arikgo's Avatar
mercedes c280
hi and did you solve it?
Old Nov 8, 2021 | 05:06 PM
Akbar Service's Avatar
2007 S600
i am not surprised that there is no response...
Old Mar 2, 2023 | 06:51 PM
ulipacmotor's Avatar
C300
Talking Intake Manifold
TOO RICH BANK 1 AND BANK 2 on 2008 Mercedes Benz C300
I would have your mechanic remove the intake manifold to check if the intake runners are damaged. One of the intake manifold runners came apart once removing the intake manifold throwing a red flag. I decided to bite the bullet and open the intake manifold, which if opened cannot be resealed, to see if there was more damage. Once it was open we found that one of the plastic intake flaps were broken. Replaced the complete intake manifold with vacuum hoses because they were off. No check engine and the responsiveness improved significantly. Would still recommend checking the Air Mass Meter, Air Filter, and vacuum hoses before going this route, but if all of this was done or checked the intake manifold is most likely your issue.
Put a video of the intake manifold flap that broke inside the manifold. It should be secured with the rest of the intake manifold flaps and should be only be allowed to move once the intake runner actuates. It would be difficult to tell if you put a camera inside. So, if you're a shop looking at this I would recommend letting the customer know that you want to open the intake manifold to confirm if it's damaged internally because as I said above the is no going back once opened and the part itself is around $800.
Also, replaced all the fuel injectors at the same time because they are relatively cheap and they have to come off the remove intake manifold. Vehicle had over 170,000 miles and is running like a champ again.
Note for mechanics if this is the issue you will have to tap the new intake manifold to reinstall throttle body due to new intake manifold not coming with it unfortunately. Obviously a bit more of a process so tell your parts guy not to be cheap and get you new aluminum bolts once the intake manifold is tapped to install the throttle body.
Best,
Uli
File Type: mov
Old Nov 30, 2025 | 08:47 PM
Jamminhi's Avatar
2001 SLK320, 2008 MB C300
This is a very old thread but I experienced the same after cleaning the MAF sensor on my 2008 C300. The CEL light appeared after driving 15 miles or so and after I cleaned the MAF sensor. I checked the sensor and it was not seated correctly when I reinstalled it. I fixed it but CEL again after 10 miles. I checked again and cleard the ECM DTC code. I then realized that I failed to insert back the secondary air pump intake into the box. It is very easy to miss because it is hidden once you reinstall the cover where the air filters are. Maybe not relevant to your case but just sharing my experience.
