w204 c200 fl av 7g gearbox questions
Old Dec 28, 2015 | 06:27 AM
cheong651's Avatar
w204 c200 2012 fl av
I just buy the second hand c200 fl av blue efficiency 2012, I have some question for 7g gear box.
frist my 7g gearbox just have s and e mode functions
When i use +/- shift, why just can up D6 not D7
same at the following,D1,D2,D3,D4,D5,D6 and return to D
Old Dec 28, 2015 | 08:18 AM
michail71's Avatar
2013 C250 Sport
It is meant to be a gear limiter (for downhill driving) and not a manual shifter. Dynamic handling packages allow for manual shifting and will have paddle shifters on the wheel.
Old Dec 28, 2015 | 09:10 AM
cheong651's Avatar
Tks,
you mean the gearbox have D7, but the gearsbox limited the speeds, so i cannot use the D7 ,i try at high way about speed up to 100 km, but also cannot up to D7
Old Dec 28, 2015 | 01:24 PM
michail71's Avatar
2013 C250 Sport
I'm not sure myself. I'm just going by what the owner's manual says. Without dynamic handling package (which would have paddle shifters on the wheel) the +/- functions as a top gear limiter. So D and D7 would be the same thing.
So if you put it in D4, the car will run gears 1-4 as normal but not shift past 4th. That is until the rev limiter is hit and then it would upshift.
Old Dec 28, 2015 | 02:43 PM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
Originally Posted by cheong651
Tks,
You cannot "up" to D7 because D means the entire gear range is available. D6 is the final gear limitation option. "D" is technically D7
Old Dec 28, 2015 | 03:36 PM
cheong651's Avatar
Tks Oh I know,but why did the c250 can up to D7,the reson is
c250 have M mode?
Old Dec 28, 2015 | 04:19 PM
michail71's Avatar
2013 C250 Sport
Oh, do you have a manual mode on your car? I think the C250 with the Sports Plus package has that.
The car would have red stitching, paddle shifters, sport button above the climate control, 18 inch wheels and an M button down by the shifter.
Old Dec 28, 2015 | 06:14 PM
cheong651's Avatar
Tks all for help
