Need help from 2013-2014 W204 owner with Star
I am looking to update my 2012's instrument cluster to the 2013+ silver design, but I am not sure which CFFs to flash in Vediamo. If one of you guys have a 2013+ W204 and a Star, could you pleaseee look at your current software settings for me?
Attached is a picture of the numbers I am looking for from a 2013+
Preferably your car would only be equipped with Attention Assist as I don't have Blind Spot, Lane Keeping or Distronic so that file would be a different file for me, but I'll take any and just play around.
To get there all you have to do is go to Vediamo -> open ECU "IC_204" and open the Flash station. The numbers I need are those with the red rectangle around it.
Thanks.
Now if you flash a HU45 CFF into the IC_204 that might brick it, but who would?
The part numbers should be the same, but in any case, the important part should be the software number. If I can get all the software numbers off a 2013 with Attention Assist only, then I should be able to do the upgrade in the same manner that I upgraded my 2012 beige head-unit to the 2013 look. I am not updating with Xentry, Xentry won't let you update past your model year in this case 2012 beige, I am using Vediamo to flash the files directly into the cluster.
Can you help me to update Comand online on W204 2011 facelift.
I have STAR & Vediamo.
Thank you.
Ищу cff файлы для пересвета в серебро ic204, HW 2049018903 помогите пожалуйста!
