Fixing BAD Touch Paint
2012 C300 4Matic Sport Sedan
long story short I have to awful touch up paint job on my hood from two small rock chips (not done by me) I've been reading on how I can fix them.
It all comes down to removing the blobs of touch up paint which have clear coat over them with paint thinner has anyone tried this? or with lacquer thinner?
I know car paint is basically baked on and from what I've read the touch up paint and clear coat should come off fairly easy by placing paint thinner or lacquer thinner on a cloth and just slowly and gently rubbing off the blobs of bad touch up paint.
has anyone tried this? and any tips?or should I not do this at all?
I'd like to avoid wet sanding and all that extra buffing blah blah blah just because I don't feel like buy all that equipment to do a small job I'll probably only do a few times.
I'm not sure you'll be able to just wipe off the bad touch-up paint with just thinner.
First, tape off the area, exposing just the "blob." Soften it up with thinner or mineral spirits. Use fine sandpaper, 200 or so, and roughen up the blob. You may have to repeat this several times.
Once the blob is gone, I have had good luck with the Dr. Colorchip system.
Good luck
Good luck
Good luck
Good luck
you think Varsol will do the job without damaging the paint in surrounding area?
I have a very fine brush and rubber squeegee like Dr. Colorchip system I was planning on using this method after i figure out how to get the awful job off.
I mean a "pro" detailer charges 75$ an hour and from 2 quotes they said 2 hours of work. its hard to believe it takes that long .... I was planning on using a thinner and a hair dryer to soften it up I'm just worried about the other paint.
i need to find out what thinner to use can't find a solid answer Canadian tire or Walmart have lots of options just need to find the best one any suggestions?
2014 CLS550-4M, 2013 C350-4M Coupe
Please do not attempt to use any type of paint / lacquer thinner to remove a bad touch up paint job. Do will almost certainly do more damage than good. Give this a try:
Also, please do not use anything more course than 600 grit wet/dry sandpaper on a touch up area. What I have used multiple times with great success to finish a paint chip touch up is:
- 600 or 800 grit wet/dry sandpaper (wet with water), next
- 1000 or 1200 grit wet/dry sandpaper (wet with water), next
- 1500 grit wet/dry sandpaper (wet with water), next
- Meguiar's M1 Mirror Glaze Medium-Cut Cleaner, next
- Meguiar's M205 Mirror Glaze Ultra Finishing Polish
Also, I usually let the touch up paint harden for a week before I finish it using the steps listed above.
Please do not attempt to use any type of paint / lacquer thinner to remove a bad touch up paint job. Do will almost certainly do more damage than good. Give this a try: Amazon.com: Blob Eliminator 2oz: Automotive
Not sure how many or how big the bad touch ups you have, but unless you are confident in what you are doing you could quickly find you have a good mess on your hands and maybe make things worse. What exactly was the detail shop going to do to fix it? I know $150 seems like a lot, but if it would address the issue to your satisfaction, it might be worth it, especially if you have multiple areas. To fix each one could take a lot of time. How much is your time/aggravation worth? Just my two sense.
Maybe try a rubbing/polishing compound on a rag and gently going over the area to smooth it out and then polishing it back out. Just be very gentle.
heres pictures awful stuff the clear coating touch up is the ****ty part from a far you just see 2 dots but up close you can see the smearing
the one thing is it doesn't really say whats in the Langka's blob eliminator but from hundreds of reviews it doesn't damage surrounding paint and works the majority of the time.
I have had great luck with Langka. Touch up paint is a different type of paint than the original paint. In essence the Langka dissolves only the touch up paint. I have used it on older touch up areas and when I do my own touch ups. They also sell a kit that contains a prep and sealer.
The run Razor works great for leveling bad touchup paint: http://www.eastwood.com/motorguard-r...ocker-set.html
Ok, here's what you do.
2000 grit wet sandpaper.
Meguires #2 fine cut
Meguires #7 final
Using water, wrap your sandpaper around a firm sponge (small as possible) and sand down the paint additions. You'll see them slowly disappear. once gone to your satisfaction, dry off the spot. grab the #2 final cut and buff out the spot until the gloss matches the area. Then wash the car and hit the whole things with #7.
I had a 2 foot scratch that someone filled in with touch up paint. I wet-sanded it out, buffed it and showed my wife - she could not believe it was gone.
Here's a great video - all by hand
Meguires #7 final
MB Marko (03-24-2016)
Never heard of this before. Looks worth trying. Thanks.
Meguires #7 final
Wet Sanding and Refinishing By Hand (Deep Scratch Removal) - YouTube
Meguires #7 final
the thing is the more i look at how they job was done i think they tried to wipe the clear with a paper towel or kleenex hahaha it just looks like theres white particles in it i just hope i can get rid of that I'm sure I can i really would like to avoid sanding it but the video is pretty convincing and looks like there is no mark of sanding at all so that option #2 if lanka blob eliminator dent work
Update: I Got my langka blob eliminator this morning and just tried it out. I rubbed it for 15 seconds then washed the spots with car soap and water and then just rinsed a few more times to make sure i got it all off, wiped dry and let dry for 30 min+ and i can say what a difference with only 15 seconds of rubbing. I might try to get rid of the old touch ups when the weather gets nicer but I'm happier that the blobs are basically gone you can hardly see the lower chip the higher one probably needs a little more but its a lot better
