Mercedes earns IIHS poor rating for headlight performance
http://www.msn.com/en-us/autos/news/...=ansmsnautos11
It seems Mercedes and BMW are scraping the bottom of the barrel on this category! I wonder if that was for the W204 or W205 mentioned in the article. The newer model is a little better.
I do miss my Volkswagen headlights (which made the top end of the list).
I drive highway 403 every weekend at around 2-3 am,Its a highway with basically no lights pitch black for miles at a time. I can't stress the amount of times I've seen deers/ animals on the road and been able to stop/slow down because of these headlights. I have 0 complaints about them.
http://www.iihs.org/iihs/ratings/veh...s-4-door-sedan heres a link to most the C class ratings
still hard to believe there poor i mean High beam assist, they move as you turn the car.....
They said "best configuration" was tested and made mention to the halogens being worse. I would have to assume the review was for the ILS system, which I would be thrilled to have.
I'd like to do the aftermarket projector retrofit some time.
Look it up in the manual- it only took about 5 minutes to adjust 'em, and it's free!
Ever since I saw that report, I didn't realize how bad my lights were.
My belief is because these modern lights are so bright (especially for those of us who have been driving since the sealed beam days), they are aimed low to avoid complaints from other drivers. Combined with the sharp upper cutoff of the pattern, the result is lights that are amazing out to about 50 feet in front of the car, while the world is totally black beyond that point. Raising the aim places the upper cutoff much farther down the road, allowing for massively better driving safety. With the three vehicles I've 'modified' this way, I have yet to be 'flashed' by another driver, as well, so I can only guess they're not getting blinded. Another plus is the high beams are amazing out in the country.
Go ahead and spend money if you must, but I would give the adjustment a try first. Personally, I love it when a solution is free!
- Curve-Adaptive LED Projectors
- Non-Adaptive LED Projectors
- Halogen Reflectors
They were all rated as "Poor". The full test results are in the attached PDF.
From the article,
"Many headlight problems could be fixed with better aim," said Matthew Brumbelow, senior research engineer at IIHS. "This is simple enough to adjust on many vehicles, but the burden shouldn't fall on the consumer to figure out what the best aim is. Manufacturers need to pay attention to this issue to make sure headlights are aimed consistently and correctly at the factory."
Some of the damn Toyota appliances they sell come factory with LED's can't believe any of the euro luxury brands still offer halogens as standard.
If Hyundai starts cutting in on the margins enough they may. Their cars manage to look like both a Mercedes and Honda and the same time. There is one Hyundai model that has a strong front lighting resemblance to a C-Class. But I can spot the Hyundai easily by the fact it has HIDs.
Mercedes know they have value in their name. They just need to be careful not to get it tarnished.
