The W204 Exhaust Thread - X-Pipe, Straight Pipe, Mufflers, etc.
Keep in mind the stock resonator is actually an X-pipe, but it has quite a bit of sound dampening.
From my experience, I’ve only experienced drone in straight piped, or un-muffled exhausts (muffler delete). You shouldn’t have any drone just doing an X-pipe.
Hoping to clarify quickly as my cousin’s exhaust/brake shop is doing the work for me but I’m ordering the mufflers and getting them dropped shipped to his shop.
For some reason the MF mufflers they were going to use if they provided them would’ve been $375 for a pair! As soon as I order the correct mufflers they’ll set up an appointment and get me in. Doing the front res delete, x pipe and MF mufflers on my C300. Aside from a few $1200 kits this is the best sounding combo I’ve heard.
Thanks!
And to those that have said they’re not cats, stop giving others false info. If you don’t know something, don’t pass on ‘info’ if you don’t know what you’re talking about. I fell victim to this and I’m sure other have too.
So I just did my x-pipe and MF mufflers and it’s not quite as loud as I wanted but it’s definitely deeper and has a nice tone and there’s no drone.
ive done the x-pipe change so far and I'm a bit disappointed about the sound. So I'm currently looking for something more loud.
So basically there's my options.
My current setup is only an X-pipe
What I can do is :
1 Delete the first faux cat whatever you call it. Is there any sensor in these ?
2 Remove mufflers replace them with magna #12226. But is there a significant change ? And what about the drone ?
3 muffler deletes and once again the drone can be a problem
I don't want to throw about 1k in that system.
Thanks for helping me again.
First I had the resonator replaced with an oval dual-in-dual-out Magnaflow muffler and the stock mufflers replaced with straight pipes. This sounded like ****. The drone was horrible and the exhaust had no character; it sounded the same across the entire RPM band.
Next I had the dual-in-dual-out muffler replaced with a Magnaflow x-pipe and round straight-through Magnaflow mufflers installed where the stock ones would be. This returned the character of the exhaust and improved the drone somewhat. It was no longer horrible and much more comfortable in the cabin. But there is still drone at highway speed.
Next I had the secondary catalytic converters removed. These are not "faux converters" because they do assist in converting the gases but they have no sensors. Removing them hardly changed the exhaust note to make it worthwhile. In fact I started noticing odd behavior from the engine at speed occasionally. It's like it was detecting the gas exiting faster making it think something was wrong, like a brief blip in acceleration during shifts, like cutting out.
Next I bought a used set of stock downpipes and was intending on getting a set of stock mufflers to return the exhaust back to stock. The drone wasn't too bad but driving 60 miles each day was starting to wear on me. Instead I bought a Megan exhaust for the car because it was cheaper than even a set of used stock mufflers. Fitment isn't great - that's another story for another time - and the exhaust sounds about the same as paragraph 2 above.
IMPORTANT!!! When having an x-pipe installed make sure you tell the shop to NOT cut off the flanges from the down pipes. If they do this you will not be able to go plug-n-play back to stock mufflers. Have the shop cut off the flanges from the resonator and add them to the x-pipe so that everything is plug-n-play. No sense ruining every component of the exhaust system.
Next I had the Megan mufflers replaced with straight pipes. Drone is a little worse than paragraph 2 above but this is by far my favorite setup. Under acceleration at higher RPM the car screams and sounds anything like expected.
If I were to do it all over again I would have the resonator replaced with an x-pipe and the stock mufflers replaced with straight pipes. Every other setup was disappointing.
That being said, no, there are no sensors there, I think that’s what lead some to think they’re not cats, but they are. Also, this is the most common cause for drone as it’s a longer stretch of straight pipe if they’re removed and it’s right under the cabin. You can find a little ‘Mom & Pop’ shop and I’d bet they’d remove em, or do it yourself.
I have the MF 11226... you can do the 12226, the only difference is the size of the inlet and outlet pipe going out to your tips. 11226 is 2.5, 12226 is 2.25”. Neither will cause drone. I personally like the sound but for some it’s not aggressive enough. From your post, it sounds like this may be the case for you, so if you keep your sec. cats you may want to just delete the mufflers. This leads me to the 3rd question....
Yea, you probably will get some level of drone. You can do a J pipe and use the formula to determine what size you’d need, or just live with it. Me, I didn’t buy this car to sound like an 80’s Camaro. I just wanted close to the same sound as my Audi S8, and with what I did I came as close as possible. If my cousin’s shop would’ve deleted the sec cats I think the sound would’ve been spot on, but they are a good shop that does quality work, not half-assed, jerry-rigged setups, plus, I do think the drone would’ve made it not worth it. Right now, with the X-pipe and MF mufflers I have a very happy medium.
To reiterate what Shimee said, you may be happiest with an X-pipe and muffler delete. For me, that’s a little too...’trailer park’ I guess..not the method, but the sound..it sounds cheap (which it is) and something you’d hear from a 16 yr old’s Honda. I don’t know.. Mine has a deeper tone but not loud, and when you rev it you get that rasp at the top-end which I like. But if you weren’t familiar with this car and heard it going down the street, cruising at 45 or so, you wouldn’t know it had anything done to it, and that’s exactly what I was going for. It seems to me the best sounding option was one of the kits mentioned in the first post of this thread. Shimee says the Megan didn’t fit right and that’s too bad cause I liked the sound of it in the post.
I had it installed closer to front then straight piped to mufflers - what a great mod!!
What you actually did was replace and x-pipe with an x-pipe. Your stock resonator IS an x-pipe, it’s just highly insulated and muffled, that’s why removing and putting one on bare adds tone. But not a 1/10 HP was gained. Still, what’s important is that you seem to enjoy your car more, and that’s the point of all of this.
my exhaust with X pipe
2011 c300 4matic
i dont know the diameter of my pipes i tried to estimate but its so close between 2.5” and 2.25” i dont have a tool for that. if anyone knows that’d be awesome.
also when the resonator is removed the xpipe seems to fit smaller into the space left;
do you place the xpipe dead center of the space with pipes of the same length to make up for the missing space?
orrrr
do you place the xpipe closer to the mufflers or further, and why would that be? any difference?
i have some notes from doing research and looking at videos but not every video has the best sound to compare with others, technology smh. id still like to see some input on what anyone has to say
so excited to try something new!
The crossover inside the stock resonator is approximately in the middle. It's about where the hole is in this pic: https://cimg4.ibsrv.net/gimg/www.mbw...5e459fcecb.jpg. If that's where it's placed it'll position the x-pipe towards the rear.
Ideally you want the center of the crossover of the x-pipe to be where the crossover of the stock resonator was. The resonator is like a muffled x-pipe. I don't know if this will affect sound or performance (probably not) but the MB engineers put the crossover there for a reason.
Please also heed the bolded advice in my previous post above.
internal diameter is 2.25 and external is 2.5, so are they the same? or is there a one thats internal of 2.25 and another that is 2.5? i want my pipes to be the same as the part i order.
seems like a lot of people order the part #10790 https://www.magnaflow.com/products/1...eel-tru-x-pipe
but some still ordered the #10791 which is the 2.5" diameter, do different years of the car have different stock pipe diameters? mine is 2011
ill heed your bolded advice, seems like i can always go back to stock
