thanks for the details about where to position the x-pipe.
internal diameter is 2.25 and external is 2.5, so are they the same? or is there a one thats internal of 2.25 and another that is 2.5? i want my pipes to be the same as the part i order.
seems like a lot of people order the part #10790 https://www.magnaflow.com/products/1...eel-tru-x-pipe
but some still ordered the #10791 which is the 2.5" diameter, do different years of the car have different stock pipe diameters? mine is 2011
ill heed your bolded advice, seems like i can always go back to stock
All these cars have 2.25'' diameter exhaust. The x pipe alone will only get you more sound in the upper rpms. From the cabin and normal driving, you won't really notice it until you get on the throttle. For some people, it may be too quiet but i've heard a c300 with an x pipe and muffler delete and it was way too loud for my taste.
Sorry I measured wrong. The external diameter is about 2 ⅜" for the exhaust piping. I measured the inlet on one of the old mufflers where it was was welded so I unintentionally measured twice the wall thickness.
When you order parts you order by internal diameter. So you want 2.25" but even if you ordered 2.5" an exhaust shop would be able to make it work. The magnaflow x-pipe cavity is the same size for multiple sizes the only difference being the inlets and outlets.
I must have browsed 1000 sites, setups, sound clips and read through most of this thread and others here on MBWorld, and have landed on 2 setups: ARH Headers + Remus catback:
Unfortunately, Remus is a gongshow and months of Backorder clients are going Meisterschaft. Also ARH isn't selling anything compatible at this time.
So here's my plan: - MBH Headers - MBH High Flow Cats - 2.5" pipe - Magnaflow #10791 X-pipe - Either:
- Magnaflow 11386 Stainless Steel 2.5" Oval Muffler (just to tone down a bit, may delete this later)
or
- 2x Vibrant 1792 Bottle Style Resonator (just to tone down a bit, may delete this later) - Meisterschaft 4x120x80 CO axelback
- Meisterschaft Glossy black tips
- Stage 2 Tune
- Jcsportline Carbon Fiber Rear Lip Dual Outlet Diffuser
or
- Stage 2 Tune
Hoping for +100whp when done.
Feedback?
Forgive me if I’m confused but I believe you’re asking about modifying a C350, so that’s what I’m basing my answers off of.
The two examples you mentioned are apples and bowling *****. You’re never going to get that C63 sound from a 350 no matter what you do.
Also, what is a “Stage 2” tune on a naturally aspirated car? Not being a jerk, I really am curious.
And lastly, you already have much more than 100 HP at the wheels. If you’re hoping to ADD 100 HP with those (or any) mods, it’s not going to happen.
Well...
I know I won't get the sound of a V8 out of a V6, I'm looking for the tone, not the overall sound.
A Stage 2 Tune on the C350 is a common tune done here in Calgary for C350's with a header. (Stage 1 is without the header)
As for an extra 100 HP, I know I'm dreaming, but realistically, an extra 25-30 is likely the best I'm going to get.
So, with all that in mind, and weighing in the cost benefits, headers are only going to get me an extra 5-10 HP, so for $3,000 for the Headers and HighFlow Cats, it's likely not really worth it.
So I'm trying 2 different projects:
1) Secondary Cat and Resonator Delete
- After cutting the secondary Cats, increased from 2.25" to 2.5"
- Replaced the secondary cats and resonator with a
- Reduced back down to 2.25" out the MF muffler
- Kept the Stock Mufflers and the tone was actually very pleasant and there is some noticeable power difference, but likely not too much
2) Cat Back Magnaflow Solution
- Replaced with a
A) You won’t come close to sound or tone. It’s difficult for other performance V8’s to get close to the sound (or tone🙄 of an AMG. It’s more likely it’ll sound like a modified Accord. I’m not saying it will, but the possibility is greater for the M272 to sound like crap than good.
B) You’d need 2 headers for a V6, and I had no clue they were available in the aftermarket for the M272. Again, what is a stage 2 tune? Is it just fuel mapping and timing changes? I can’t imaging messing with the timing on a variable timing engine. I suppose it’s not impossible to squeeze 20-25 hp with good headers and crafty mapping. But it’ll be in the top end. At that point it’s up to you if it’s worth the cost.
C) 100 hp gain isn’t dreaming, it’s close to impossible, er, improbable and impractical actually. You would need forced induction and much more and would have to spend much more than the admission price of a well sorted C63 to get there. And even THAT’S dreaming. 😴💭
Now I do understand the Canadian C350 has 268 hp..? And all the exhaust modifications you listed won’t net you near 20hp, you’d be lucky with 5. I’m not familiar with many ‘tunes’ for that lump. I’m not giving you a hard time, it’s just not common to wring much more out of today’s non-performance, naturally aspirated engines. Now with many of today’s turbos it’s common, easy and relatively cheap to get gobs more power with just a basic tune. Shoot me a link to this tune up in Calgary that you mentioned if you could. I’d like to see what you’re seeing.
My opinion is.. make it sound how you like, look the way you want it to, maintain it and enjoy it! But if you have lots of disposable income ( or are a very disciplined saver) and don’t frustrate easily, more power to ya! (Not literally unfortunately 😁
Anyone install a Magnaflow 11226 single muffler on a W204 with either single oval or dual oval or round tips? any issues fitting as stock replacement or hangers etc. is it something most muffler shops can do? any insight photos would be appreciated.
UPDATE: Just spoke with a muffler shop and they recommend keeping stock exhaust since the c250 is a turbo the back flow could effect the turbo in either lack of performance or damage to the turbo, any thoughts?
I have a straight through Flowmaster Outlaw 2.5" with 3" tip. I've had the Flowmaster Outlaws on my last five cars but this was the first turbocharged one and somewhat disappointing as I like my exhausts really loud. It is more noticeable than stock so I guess I'll just have to live with it.
I had the muffler replaced first and it was barely a whisper above the stock muffler. A week later I had the resonators removed and that upped the volume a bit more. I haven't noticed any performance gains or drawbacks to changing out the muffler but it is only a 200HP turbo 4 cyl. Flowmaster Outlaw 2.5" 3" slant tip resonators deleted side view resonators deleted rear view
Thanks for your experience,it really helps and to see that you had no real changes in performance or sound. I put an Eisenmann on my slk 320 v6 on another car and was considerably better sounding not much performance change and the price was $$$$$ i have been reading about other using the magnaflow 11226 and getting a sound that im liking close to my eisenmann and much less $$$. im still on the fence if its worth it? and i have concerns about the change in turbo back pressure or ruining the turbo
When I first replaced the muffler the only thing I gained was a lighter car as the OEM muffler is heavy, no real sound or performance improvements. there is a noticeable change in sound only after I removed the center resonators, and then it really needs to be above 4000RPM to enjoy the sounds but still no notable performance. Does not sound like an Eisenmann but better than stock. I've had this muffler on non turbo 4 cyl cars and they were loud AF no matter what RPM, maybe just the nature of a turbocharger. I was hoping for an Eisenmann when I had a V6 C300 but I couldn't justify the price at the time and there is nothing available for the C250s. You would think Eisenmann or Akrapovic could've done something with these cars.
I hear you about eisenmann at the time I had money to burn that was quite a few years ago my slk was a 320 manual transmission and sounded great! I’m finding same thing not much out there for a 250 turbo. Not sure if it has anything to do with turbo requirements? I found what looks to be next best thing to the eisenmann is the Meistershaft about half the price of eisenmann Still way more than the magnaflow. Megan Racing has some interesting mufflers not sure if those are
more volume than I’m looking for. Mine is a coupe and I’m finding what works for a Sedan won’t work for a coupe not sure why that would be? Anyway thanks for entertaining my quest!
Hi, I recently owned a 2012 w204 fl and i am converting it to a c63. i have some questions about exhaust. do i need backpressure for my exhaust system? i am currently thinking to start a downpipe project, i will not remove the cat. i have some questions but i couldnt find any answers.
I am wondering about the turbo on the 4 cylinder since I’m learning the turbo is sensitive regarding the turbo back pressure and actually loosing power if changed. If yours is the 6 cylinder don’t believe it’s an issue. There are some YouTube videos by a guy flex that has done the mods without problems. Hope you get some info
I just had my resonator swapped for an x-pipe and Magnaflow mufflers installed and there’s no drone at all. You can hear the exhaust a tiny bit in the cabin but I just drove 2 hours and there was no drone at all.
Hi, a first-time poster on the forums I have a 2011 C300 Sport and did a resonator delete with an X-pipe install (Magnaflow 10790) about a year ago. 4 or so months after that I did a muffler delete to chase the louder, deeper sound, but I have a lot of highway driving coming up soon, and will not be able to handle the drone in the highway for that long. I saw the videos of the Magnaflow X-pipe and Muffler setup already, but none of them testified well to the amount of drone I'd get with that setup. I've heard mixed opinions regarding the amount of drone with Magnaflow Mufflers and an X-pipe, and I wanted to set the record straight.
So my question: Will installing Magnaflow mufflers with the X-pipe cause excessive drone at highway speeds (around 2.3 - 2.6k RPM), or is installing the stock mufflers back the best way to go? I love the volume and the tone but it's not worth it for my sanity ha-ha.
I will chime in, if I may.
I had a PFL 204 with the 2.5 M272.
Did all the above with a Eurocharged tune, custom made airboxes, K&N's...
No matter what I did, it sounded crap.
With short tube headers, Magnaflows or Armytrix ((Long story) back boxes with 2.5" piping front to back and de-catted, an X-Pipe (up front and at the back in turn), there was this horrible "moan" followed by a howl (more painful than baleful) above 3000 RPM. It was actually embarrassing it sounded so bad.
Chucked everything away, stock mufflers, the Eurocharged headers, just decatted, Sounded best like this.
I also think I lost a chunk of low end torque.
YMMV
