Lightning package for 2013 C 300 Sport 4 Matic
Old Aug 3, 2016 | 11:49 AM
bbollapu's Avatar
Hello All,
I have a 2013 C 300 Avantgrade Sport 4 matic. It has all the available packages minus the Lightning package. So, I have bought the after market headlights. I have few questions
1. When do the C shaped LED Strip turn on? Right now it turns on along with the Xenon Projectors. How to turn on only the C LED Strip?
2. The small bulb behind the C shaped LED never turns on. Even though I put on the high beam, only the projectors beam increase but the small bulb doesn't glow.
Do anyone has come through these kind of problems? Also, any suggestions on how to turn on only C shaped LED are welcome.
I am also planning to take it to the Mercedes Dealer. They charge $139/hr for only labor.
Thanks In Advance.
Old Aug 3, 2016 | 03:26 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W204 forum...
Old Aug 11, 2016 | 12:24 AM
97 GSX 97's Avatar
2014 C300 Sport
I have a 2014 with the lighting package.
1. The C shaped LED is on at all times when the car is turned on, and the low beams or high beams are on.
2. The small bulb only turns on when you turn the steering wheel to the left or right while the low/high beams are on. They are used to give you more light through your turn, and turn off after 2-3 seconds of your steering wheel going back to dead center.
PS good luck. I hear those C shaped LED's on the replica's burn out a lot.
