h&r sport springs uneven sides
Old Sep 25, 2016 | 06:00 PM
kavadarci's Avatar
2012 C350 Edition 1
Hi, my front are good but the back the right is 2cm higher than the left.
I have four dots rubber on both and just removed the higher one. Top an bottom are seated properly.
I will remove the shorter one but I thought the problem will be with the higher like I've missed the grooves or something.
One week since installation.
Any help is appreciated.
Old Sep 26, 2016 | 02:02 PM
Isaac13's Avatar
2013 C350, 2013 GL450, 2018 G550 4x4^2
Please explain again, four dot rubber? Not sure what that means. Shorter/higher one, again not sure what that means. Are you talking about the spring pad/isolator? If there is a big difference take the springs out and make sure they are the same and equal in length. Pics would help
Old Sep 26, 2016 | 03:40 PM
kavadarci's Avatar
2012 C350 Edition 1
each rubber above the spring in the back is different thickness.
Factory is 1 dot or 13mm, i used 4 dot or 17mm; otherwise the back will look way too low compared to the front.
I removed the side that sits higher which is the right rear and all looks good. correct rubber and sited properly in the top and lower grooves\notches.
I need to remove the lower side or the left rear to see if everything is ok there.
When i looked at the springs in the box they looked the same length and they have the same markings.
Attached Thumbnails h&r sport springs uneven sides-img_20160917_145958.jpg   h&r sport springs uneven sides-img_20160920_185607.jpg   h&r sport springs uneven sides-img_20160924_153243.jpg   h&r sport springs uneven sides-img_20160913_184639.jpg
Old Sep 26, 2016 | 04:04 PM
Isaac13's Avatar
Call me crazy but I think you have a defective rear spring. Look at the amount of coils on one versus the other. One side has 8 and the other has nine. Just a mistake in manufacturing or change. Tell them you want to send them those and give you back the same... It may not be a defect but enough to make it not the same
Old Sep 26, 2016 | 04:09 PM
kavadarci's Avatar
2012 C350 Edition 1
I wouldn't call you crazy.
The springs are not in the same position in the box so can't really tell.
I should have measured them but I never thought German made springs will have such a significant defect.
I would count the coils on both to confirm the springs are not th same.
Old Sep 26, 2016 | 07:02 PM
CGC's Avatar
CGC
2009 C350
Have you called H & R? They are extremely helpful. I used to be an H & R distributor and they make some of the best springs on the market IMHO.
