c200 head gaskit
Troubleshoot all of your cooling system first. It would be a shame to do a head gasket and then have the car overheat again because you didn't fix the first problem.
The blown gasket is BECAUSE of the overheating, not the original cause.
With the engine hot ie thermostat open inspect to see whether there are any bubbles venting from the coolant fluid in the header tank ( reservoir).
Careful taking the filler cap off.
You may not have bled all the air out in the first instance. It may be a good idea to let the engine heat up in the garage with the bonnet open & let it cool a few times before driving . The coolant system should vent automatically into the reservoir tank.
Good luck.
Good luck.
