Subwoofer firing through hole in rear deck?
Im not a basshead or anything I just wanted to add some solid low end to the factory system. I mostly listen to rock but I do listen to some hip-hop so Id like some bass-heavy, lowend extension/control. My goal was to try not to cut up the rear deck and make any modifications outside of some bolt/screw holes.
I was looking to mount a sub box to the underside of the rear deck inside the trunk with a baffle ring around the sub, sealed against the deck to isolate the subs sound waves into the cabin reflecting off the back glass.
I was originally thinking about 2x 8" subs in a sealed box but looking at the deck Im not sure I can use more than one without cutting another hole and Im not even sure I have a viable hole for the one.
I labeled all the holes in the pics for easy reference.
Would I be better off trying to find a super-shallow-mount sub to replace the factory sub, building a thin box for it(fiberglass?) and then mounting it back in the factory location above the rear deck inside the cabin? I havent taken apart the rear deck yet so I dont know what it looks like from inside the cabin without all its trim pieces on and there are no good pics of it that I could find on the internet. Ive only been able to find a picture of the sub itself. Does a sub that thin even exist aftermarket and would it even be an upgrade worth doing(amplified of course)?
If anyone has any suggestions or experience with this please let me know.
Besides, I have a bunch of Zapco amps(500.1, 350.2, 750.2) and some Partsexpress speakers that have been collecting dust.
I have seen and built sub boxes onto the deck lid. They can work good, but you have more chance of rattle from the decklid itself. Make sure and use dynamat.
Another thing Ive considered is building a bandpass enclosure and running it straight to the cabin instead, to avoid the port/speaker handshake issues referenced above. Any thoughts?
