Economy Maintenenace
I looked around a bit but I haven't been able to find the correct answers. Essentially what I need to know is what maintenance measures do you guys take to ensure peak fuel economy. I do normal oil changes and recently I have replaced spark plugs and air filters on the car. What else should I look at? My economy has been falling drastically lately. Plus with it getting colder this time of year it will be getting a little less and less.
With temps getting lower most folks are probably not adjusting their tire PSI accordingly, which would be to add more air. Make sure your tires are set to the proper PSI in the morning prior to taking it out for a drive, since proper reading must be done cold.
Low PSI tires yield lower fuel economy.
I will check that and see just to make sure. I was leaning to something more mechanical causing the decrease in efficiency.
New tyre brand?
Changed fuel supplier or lesser quality of fuel.?.
Changed address ie higher altitude different fuel air mixture.
Empty car of any unnecessary load ie golf clubs, & tow ball tongue.
Children or wife driving car !
Good luck & congratulations on noticing the change & for taking action.
There are not any codes that I am aware of. I did have a fuel evap code a couple months ago but it went away and I presumed it to be the gas cap wasn't tightened all the way.
I don't notice any excessive heat or the car doing much else different.
New tyre brand?
* Still Michelin Super Sport tires
* No, I still fuel at the same gas station. I do not think that they have switched fuel suppliers.
* No still the same address
* Car still has hardly nothing in it at all times.
* No one else drives my car other than me.
As far as cleaning fuel injectors. Do you guys physically take them out of the engine or do you just use some type of cleaner such as Techron through the fuel system/tank?
For comparison, this picture was taken during my morning commute 3 days ago.
EXAMPLE:
There is a reason why Mercedes recommends +3 for "high speed driving" and it's not a coincidence that it matches Tire Racks recommendation to the tee.
http://www.tirerack.com/tires/tirete...jsp?techid=301
I do not have the stock tires any longer, but I do recall it being a W-rated tire (factory ordered). Mercedes in stock form also has an electronic speed limiter rated to 130 mph, which if you look at the link above, will show you that if you intend to test the limiter, that your tires should be increased to +3 PSI (which in our case is 39/42). For those that got H-rated tires it's even worse, as they should be running +5 if they intend to go that fast, even though their tires will feel like hockey pucks on an average commute (and yes, you can blame the W204's that were shipped with H-rated tires to be the primary cause for the limiter to be set so low, since the limiter can only be as high as the lowest tire/wheel combination).
Now...if you run Y-rated tires like I do now (Micheline Pilot Super Sports), you can technically run lower pressures since Y-rated tires have higher heat ratings.
http://www.tirerack.com/tires/tirete...jsp?techid=302
HOWEVER...Since I have a tuned W204 with an unlocked ECU, I prefer to stick to the +3 PSI even for Y-rated tires so I can safely go 149 if I choose to and after having gone through 3 sets of tires in the rears, +3 is the most I'll go for daily driving (since +3 shows a very slight sign of over inflation when I took my last set beyond the wear bars, but you get the MPG results like in the post above).
