Can not remove key from MB C300 Please help
Old Nov 27, 2016 | 02:09 AM
JAGL's Avatar
Mercedes c300
Hello to you all, I am really frustrated that my car won't start up and the key fob is stuck. I am worried on why this happened due to my car only having 36k miles, it is an 09 model btw. May someone please help me out on how I can safely remove the key. Thank you
Old Nov 27, 2016 | 04:09 AM
guhvies's Avatar
2017 C43 AMG Saloon
This may read as obvious but if you have an auto then foot on brake, put in park, turn key totally off and pull key out.
Old Nov 27, 2016 | 02:01 PM
JAGL's Avatar
Mercedes c300
I tried that so basically the key does not want to turn into the position 0, which is the position the key can be removed and inserted. As for moving the gear, the only way I can move it is by removing the leather component and pressing this yellow button that allows me to move the gear. Therefore, the gear is on park and foot off the pedal but still will not turn to the position 0
Old Nov 27, 2016 | 04:45 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Is it not in park?
If it is in park put it in reverse then adjust vehicle back to normal pos, park and turn.
Old Nov 27, 2016 | 09:40 PM
JAGL's Avatar
Mercedes c300
It is in park. Im not sure if the problem is the Electrical Ignition system that failed of Electrical steering lock. The strange thing is that I was listening to music when it suddenly shut off and then the problem arose.
Old Nov 28, 2016 | 01:01 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Ahh, may not be of ay help but I wondered whether you had run the battery down using the radio.
I would check whether your battery is serviceable or maybe recharge it overnight.
Good luck.
Old Nov 28, 2016 | 10:07 AM
Colin G's Avatar
2008 C-230 4Matic Sport
Check your battery. What year is your car? Still have the original battery?
Old Nov 29, 2016 | 02:48 PM
Carsy's Avatar
JAGL,
Any Joy ? John.
Old Nov 30, 2016 | 03:32 PM
JAGL's Avatar
Mercedes c300
Solved #Blessed
Ok everyone thank you for giving me tips on what to do so I found the solution. I contacted a family friend whom is an expert in mercedes and owns a shop that repairs european cars. Charging my battery did help because that is one of the reasons why my car turned off, but the real issue was the key getting stuck. Therefore, the solution was fixing a part on the break pedal. Apparently it was faulty and it would not release the key. So what he did before replacing the part he removed the cover of the gear shifter pressed a yellow switch that allows you to move the gears and pushed the gear with force to park. While doing so he also moved the brake pedal and pulled the key.
Old Nov 30, 2016 | 03:33 PM
Adi-Benz's Avatar
Therfore, the sol
You left us wondering
Old Nov 30, 2016 | 03:41 PM
JAGL's Avatar
Mercedes c300
Sorry I have been really busy with final exams coming along this semester but im back with a solution. Once again thank you to you all for helping out with tips!
Old Nov 30, 2016 | 04:02 PM
guhvies's Avatar
2017 C43 AMG Saloon
So it wasn't in Park. My advice was correct. Yeah!
Old Nov 30, 2016 | 04:42 PM
Carsy's Avatar
Thanks JAGL for the update. Well done on the fix.
