Hood won't open
Old Feb 8, 2017 | 10:33 AM
CGC's Avatar
CGC
2015 SLK 350
Hood won't open
When I pull the hood release it only unlatches the driver side. Has anyone dealt with this? I assume I will have to go through the passenger side wheel well to get it open and then assess the problem and fix. I was just hoping someone had an easier trick to open it. Any advice appreciated.
Old Feb 8, 2017 | 10:56 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Pull it more
Old Feb 8, 2017 | 10:58 AM
CGC's Avatar
CGC
2015 SLK 350
Originally Posted by Adi-Benz
Pull it more
LOL, if it were only that easy. I even pulled on the cable as hard as I could to see if it would help.
Old Feb 8, 2017 | 11:27 AM
Adi-Benz's Avatar
Sometimes when I'd pull mine it would sound like it would open but it wouldn't. I'd go back and pull it harder and it would work. Thought it was worth a shot :P
Old Feb 8, 2017 | 11:40 AM
CGC's Avatar
CGC
2015 SLK 350
I'm willing to try anything before diving in through the wheel well.
Old Feb 8, 2017 | 12:35 PM
CGSColin's Avatar
2010 C300 4Matic Sport
Have you tried pulling up on the hood on the stuck side to see if you can unstick the latch? The passenger side latch was gummed up on mine and would stick like this and just pulling up on the hood would free it. I sprayed lithium grease on the latches after and they haven't stuck since.
Old Feb 8, 2017 | 02:55 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Try easing the spring load on the catch by pushing down whilst someone else pulls the release. If not try a firm jiggle motion .
Lubricate the hinges & catches if you do get it open. You may have to adjust the wires as they may have stretched.
Old Feb 9, 2017 | 10:44 AM
CGC's Avatar
CGC
2015 SLK 350
I had someone push, bounce and lift on the hood while I pulled the lever. Nothing worked. Seems very stuck. Any other options?
Old Feb 9, 2017 | 02:12 PM
guhvies's Avatar
2017 C43 AMG Saloon
^^ WD40???
Old Feb 9, 2017 | 02:33 PM
Carsy's Avatar
Can the hood lever be removed under the dash?. You may then be able to create a little more length of "pull" wire .
Old Feb 9, 2017 | 02:52 PM
w204_Generic's Avatar
2011 C300 4Matic Sport
When you or someone pulls the lever, have yourself or someone pull up on the hood while the hood pops up. Make sure to do this AT THE SAME TIME as the lever is being pulled?
Just a suggestion; something might break if otherwise, so do not take my advice if you do not want to risk breaking something.
Old Feb 9, 2017 | 04:52 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
Everybody needs a little extra length!
Old Feb 9, 2017 | 05:05 PM
tommiett's Avatar
2015 C350 Sport
Wrong.....
Speak for yourself..
Old Feb 9, 2017 | 05:40 PM
Alfadude's Avatar
2012 C300 4Matic
Might also depend on how big your hands are and how orange your skin is.
Old Feb 9, 2017 | 06:38 PM
Adi-Benz's Avatar
Wait so
LOL
Old Feb 12, 2017 | 05:36 PM
CGC's Avatar
CGC
2015 SLK 350
So as it turns out, the cable has a small plastic notch were it inserts into the latch to hold it in place so when you pull the cable it moves inside the cable sleeve. This 1/16" piece of plastic is apparently supposed to last the life of the car... Thanks Mercedes, but you failed at engineering on this one.
At least the cable was easy to get to through the wheel well.
Old Feb 12, 2017 | 06:35 PM
Adi-Benz's Avatar
Yeah our transmissions are supposed to live the life of the car too.
Old Feb 12, 2017 | 10:55 PM
Carsy's Avatar
Always great to hear about a problem being solved.
So many do not bother ,
thanks.
