Change a lightbulb (rear license plate)
You have to remove the trunk liner trim and come at the light bulbs from the "inside" of the trunk and access the lights from behind the assembly.
It is very easy to do.
This will help.
http://www.pelicanparts.com/techarti...im_Removal.htm
This will help.
SPONSOR/MBworld Guru
pop push pins on the liner and remove the screws from the plastic latch cover. I believe there's a DIY already posted on the w204 subforum here.
Your rear plate bulb uses 194/T10/W5W wedge bulb. We have pure white error free canbus LEDs for those if you want for it to look like newer modern vehicles.
