2010 c350 rear deck/sub rattle
2010 C350 4MATIC
Hello,
Does anyone know how to take off the rear deck?
I have this very annoying rattle in the rear deck when the sub hits certain frequencies... doesn't matter what sounds settings i have i always get the rattle.
The rattle disappears when i push the deck with my thumb.
I want to take it out and dynamat it along with some foam strips.
Anyone ever have this problem? i searched and there are lots of threads but none that show how to remove the deck.
thanks
thanks
Would be nice to see an answer to this question. I'm starting to get a rattle there myself, and not just when the sub hits very low notes, it does over bumpy roads too. My car has fixed rear seats and its not immediately obvious how it all comes apart.
I just looked on You Tube and there are a couple that show how to remove rear seats. Saw nothing that specifically dealt with how to remove the rear shelf and what might be the cause of the rattle but they may work for you. Its too cold here to be working outside right now!
Mine does the same. Hitting my sunshade button to cycle it up and down helps for a little bit but doing a permanent fix would be better.
2010 C350 4MATIC
