Steering wheel wont go up or down
http://www.benzworld.org/forums/2217418-post14.html
EDIT: Damn, it is for the S class. Will have to keep looking.
There's no reset for it, it has to be freed up (smacked downwards), then the normalization of the seat and steering wheel is re-learned in the drivers seat adjustment module. If you follow the bulletin, and update the software in that module, it will reduce the chance of it jamming in the future.
Calgarian (05-27-2021)
The motor jams in the up position, by default it runs up until it hits the mechanical stop every time you use the easy exit feature.
There is an updated motor that is bigger and stronger and doesn't jam up nearly as much.
You can install it yourself, if you're comfortable with working under the dash, remove the footwell panel and you should see both motors, it's the one on the side, try to actuate it and you will see one move and the other not. Fairly simple to change but not that cheap.
Or, you can whack the steering wheel with your hand downward and it will almost always free up and work for a good while. A nice application of grease on the little drive mechanism helps it not to jam up as often. The bulletin says to extend the wheel as far out as possible then strike it sharply with your hand downward while actuating the motor downward. The bulletin says to then perform a software update, I assume it turns the motor off at a lower torque so it doesn't jam as hard.
1) I had to first unplug the ESA-D module and reconnect it. This allowed my tilt lever to actuate the motor again. Previously, pressing it downwards made no more sound. Now the lever seemed to actually attempt to tilt the wheel.
2) I struck the fully extended wheel downwards with my hand a few times while pressing the tilt lever downwards. Tilt lever seemed to stop activating the motor again.
3) I tried the seat memory button and that was when it finally tilted back down to my memorized position.
4) I turned off the damn easy entry/exit feature.
Thank you for your help! I think resetting the ESA-D module made the difference. I was whacking my steering wheel like crazy before and it didn't help.
After battery replacement, the rain sensing front wipers and the steering wheel up-down functions - previously inoperative - appeared. I wonder what year the improved steering wheel up down motor was standard?
Great little Iridium coupe - and this site sure helps.
ez
ez
Got it. Saw your message and followed your other tips to fix it in my car.
I don't know if it ever became standard on the 204, I've seen it on the 212 and other vehicles, but the small ones are only ever found in 204/207 cars, in my experience.
#33
In my facelift LHD car, its under the driver's seat. Reach down with your left hand over the front-left edge of the seat while you're sitting on it. The connector is quite large and sticks out a bit.
#34
Will this work on 2013 C250. I just noticed today that my steering wheel is not going up or down, it just makes a noise when I press up or down. I checked under my seat and there are two connectors yellow and black not sure which one to disconnect. I just got this car two months ago with 59,000 on it.
#35
If you hear a click or thump and it doesn't move, it's probably jammed up. You need to free it, extend it all the way out and hit it downward with your hand, very firmly (don't be afraid of it), while pressing the lever to adjust it down. It should free up.
#36
Thanks. I tried that today, but I wasn’t hitting it firmly. I will try again.
#37
It worked 👍. Thank you
#38
#39
This happened in my 2014. It was repaired under warranty. There was NO MECHANICAL ISSUE. The steering wheel simply lost track of what position it was in. I.E.: it thought it was all the way up when it wasn't. The dealer reset the position parameters and everything has been fine since.
I did use the manual control lever and even banged it a few times prior to this, which temporarily fixed the problem. BUT, the dealer steering wheel position reset cured the problem.
MercAMGgts2016 (07-25-2019)
#40
#41
#42
I had the same problem and if your trying to fix it yourself make sure the convenience feature is set to on, i tried hitting it as hard as i could at least 10 times it didn't work. Turned the convenience feature on and pulled the steering wheel all the way in/out (full motion) and after 2 tries of hitting it worked.
#43
I also had the same problem, what I did was while pulling the lever that lowers the steering wheel in the down position I was also pulling down on the wheel at the same time. The wheel moved and now when I exit the car the wheel lifts up and the seat goes back. Try it it might work for you.
Nelson
Nelson
#44
February 2018 - using Mercedes Emergency Road Service 1-(800) number per the nearest M-B dealership - an immaculate service tech arrived at my place.
His M-B van (also spotless) was a part department on wheels. He replaced the age 6 battery (I'm both proactive AND ****), checked the charging system. I paid. He left.
Later I noted the previously absent steering wheel up and to the side was now operative. ........................the car is CPO and - since delivery - this feature was non-operational.
This feature has again vanished. I really don't need it.
Is there a downside to "leaving sleeping dogs alone" and doing nothing?
all the best, amigo
ez
#45
Hi Joe,
all the best, amigo
ez
all the best, amigo
ez
#46
HI JOE,
APPRECIATE - AS EVER - YOUR RESPONSE.
MY MB STEERING WHEEL REMAINS IN THE NORMAL DRIVING POSITION. DOES NOT SWING UP/OUT UPON DEPARTURE.
IT WAS LIKE THAT UNTIL NEW BATTERY INSTALL BY MB TECH AT MY HOME. THEN - IT DID SWING UP/OUT FOR A SPELL. NOW IT REMAINS IN THE DRIVING POSITION................WHICH IS OK WITH ME......AND HOPEFULLY THE COUPE!!
THANKS AGAIN, EZ
THANKS AGAIN, EZ
#47
HI JOE,
THANKS AGAIN, EZ
THANKS AGAIN, EZ
#48
Same problem and resolution on my 2013 C207 (E350 Coupe)
My 2013 E350 Coupe has the "4-way pwr tilt/telescopic steering column -inc: memory, programmable easy-exit feature" feature. The up and down adjustment stopped working recently when the temperature went below freezing and the car had been outside.
I discovered this thread via the Search function and tried many of the tips without success. Based on some additional research, I found the Mercedes Star Bulletin about the software upgrade for this problem (see attached file)
I spoke with the local Mercedes Service Department about having this software update applied. I was advised to that there would be a $209 "Diagnosis Charge" to have the SW update performed. I then asked to speak with the Service Manager about this charge. I was connected with the Senior Service Advisor who offered to look at car with no charge if I would bring it in.
He tried whacking the steering wheel from both the top and then the bottom while pressing the adjustment lever without success. He then said he would need to bring it into the shop to see if the Up-Down power motor adjustment was broken. I agreed to this.
It took approximately an hour to resolve the problem Here is what was done:
The dealership also washed the exterior and vacuumed the interior.
Going forward, I will leave the "easy-exit feature" turned off to minimize future problems.
I hope this information helps a fellow owner resolve this problem
- Cleared the code from the system to "Normalize" the system
- Cleaned and re-lubed gear mechanism for the "up and down" motor adjustment
- Applied the SW update
#49
Same problem on 2014 C300 in/out okay, just click on up and sometimes click on down. Fiddled with switch, activated and deactivated convenience setting, banged a few times on steering wheel, fiddled with switch more, fiddled with switch more. Whaddya know, started working again. Keeping convenience setting off.
Thanks mbworld
Thanks mbworld
Encountered this issue today. No motor noise when using the tilt lever. Only a single click sound when pressing the lever upwards. No sound when pressing the lever downwards. Hitting my wheel does nothing to free it up.
Can anyone confirm that this is the part number for the new motor?
A 204-460-08-25
https://www.mboemparts.com/oem-parts...bly-2044600825
A 204-460-08-25
