Need Help, w204 Knock limit cylinder 4 exceeded
Old Jan 21, 2018 | 05:37 AM
yazankinany's Avatar
Mercedes-Benz C200 W204
Hello all,
I have a 2012 MB C200 CGI, a few days ago during the cold weather, the car started to shake roughly when starting the engine like it is going to shut off. But when it gets warmer it begins to act normally. I also noticed that when I'm driving at a higher speed then braking to stop at a traffic light the car start losing power at the last second before stopping, RPM drops down and it feels like it will turn off with a little shaking. I scanned it for error codes and there were two codes both same " Knock limit on cylinder 4 was exceeded". My mechanic suggested that it might be oil pump issue and that I should flush the engine and clean it as this loss in power may be happening due to some dirty oil and engine.
I'm having my doubts and I don't want to pay for unnecessary services without fixing the issue.
Any Ideas ??
Old Jan 21, 2018 | 11:26 PM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Hi
I think you should fill up the tank with the highest octane fuel available to you clear the codes and drive for a few weeks to see if the fault code returned, I am betting it doesn’t. I am guessing your car may have had some short trips lately and with winter sometimes the oil companies fiddle with the fuel octane and cold weather additives just may have taken some time to clear it out. Not oil pump related or dirty oil.
Your Mechanic what more can I say here, it is up to you where you take your car to be fixed but it always pays to do your due diligence.
Old Jan 22, 2018 | 09:04 AM
Thanks for replying, I really appreciate it.
For the record, I’m using the recommended fuel which is 95 octane premium. I really don’t know what is the issue here. could it be a leaky cylinder or a fuel line ?
If anybody knows, please tell me what else can give this code fault.
Old Jan 24, 2018 | 05:08 AM
alecmascot's Avatar
W204 C220CDI 2011
Maybe something to do with this :
https://mbworld.org/how-tos/a/merced...buildup-389009
Old Jan 24, 2018 | 07:17 AM
Originally Posted by alecmascot
Thank you for replying, It could be, but the jerking when approaching a stop can be due to many reasons. I just want to know the main reason behind the code that I had stored, and if it is all related/connected or no.
Just to decrease unnecessary checks costs as it very expensive here in Bahrain and it is hard enough to find a proper mechanic to deal with in the first place.
Thanks again.
Old Jan 24, 2018 | 07:20 AM
alecmascot's Avatar
W204 C220CDI 2011
Originally Posted by yazankinany
I just want to know the main reason behind the code that I had stored, .
You never posted a code....just a possible description ????
Old Jan 24, 2018 | 08:29 AM
My bad, here is the code P233622.
Thanks for replying.
Old Oct 24, 2020 | 08:04 AM
EN2012's Avatar
E250 CGI W212
I had a similar issue. It turned out my battery was dying. So I just replaced the battery with a new one.
Old Jun 16, 2022 | 05:17 AM
cckcck daniel's Avatar
w204
Hello all,
Any Ideas ??
Wondering if this situation has been resolved? I have the same situation
