ran out of washer fluid
1 Post
2010 C-300 4Matic luxury
Hello, I ran out of washer fluid and now it does not work. I can here the pump running but it does not squirt ? Do I need to reprime it ? If so how do I do This. Thanks
If its cold where you are and you hear the pump, maybe ice built up in the system. Don't force the pump just fill it up and try it in warmer climate. Or the pump fried because it ran dry and what you hear is a stuck pump, its an easy fix either way, the pump is right behind the fender liner.
1 Post
