Cannot get clip style hose clamp back on. any suggestions?
Old May 27, 2018 | 05:08 PM
enjracing's Avatar
2017 AMG GTS
hi all. i just put a new air filter in my wife's 2013 c350 sport, and I cannot reclip the clamp that connects the air meter elbow to the air box.. as the clamp has rounded-edges, my needle-nose pliers just slip on it. any suggestions on how to reclip it without having to buy a special clamp tool? I also think my needle nose pliers are too short. thanks for any help. attached is a pic oft he clamp.
Old May 27, 2018 | 05:57 PM
michail71's Avatar
2013 C250 Sport
I think that looks like a one time use clamp. You can replace it with a worm drive clamp from the auto parts store.
Old May 27, 2018 | 05:58 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
I have had better luck with a set of regular pliers set to the wider opening slot and pressing down hard while trying to compress the clamp. When the little 'hook" part is shot, I just use a worm hose clamp although, like you maybe, I like the OEM look if possible.
Old May 27, 2018 | 06:08 PM
michail71's Avatar
2013 C250 Sport
I think those style clamps are to help save time in manufacturing.
Although I thought the one on my car had a worm drive connecting to the airbox. I don't have the car anymore so I can't check. The C250 airbox is a major PITA to clamp back in place.
Old May 27, 2018 | 07:31 PM
enjracing's Avatar
2017 AMG GTS
tnx gents. yea, i'll try the big regular adjustable pliers, and if that doesn't do, it i'll buy a normal hose clamp. I think you are spot on about the reason why they use these stupid things. so annoying.
Old May 28, 2018 | 01:03 AM
IGB's Avatar
IGB
'08 C300 MM Pano
^^That^^, and they are a one-sure-size that is known to fit perfectly on the MAF housing inlet...
So be mindful not to over tighten a worm drive clamp if you end up using one. You don't want to crack the MAF housing...
Old May 28, 2018 | 02:19 AM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
You just need clic-r pliers...
A bunch of companies from all over the world make them. The taiwanese and Chinese ones are around $10.
Old May 28, 2018 | 08:56 AM
enjracing's Avatar
2017 AMG GTS
beat me to it! yep, just ordered some 10bux ones on ebay. I'm sure my wife is ok to drive the car for a few days until they arrive, as the connection is really snug even with the clamp undone. tnx, mate.
