Help! Brake issue.
Thursday my check brake fluid level low light came on in the center of my dashboard. I stopped at my dad's mechanic (only works on foreign cars). He filled up the reservoir and said it can be one of three things. 1) My brakes need to be replaced (they don't) or 2) there is a leak somewhere or 3) there is a sensor that is bad that is triggering it. Anyway, yesterday I was driving and the same light came on again. So again, I stopped (somewhere else this time) to fill up the reservoir just to get home (I was maybe 20 minutes from home) and by the time I pulled into the parking garage of my apartment building, the light came back on. Now, when I hit the brakes, my car stops almost instantly, like I don't feel that there is a leak but then again I'm not a mechanic.
So 2 questions, could it be a sensor issue? & anyone who has experienced this, how much would this cost me approximately?
Thanks!
When you say you add more brake fluid, how much are you adding each time? Is the level low before you add any? Cause that does sound like a leak. When the light turns on, is the level in the level low?
Do you see any drops or a puddle of fluid under your car? Brake fluid just doesn't disappear. How much fluid did the mechanic put in? If it was a good amount I am surprised he let you leave without doing even a cursury inspection to see where the leak was.
How much fluid did you put in? You should get that checekd out right away. Not something you want to be driving around with
There wasn't even that much fluid missing. The first time on Thursday it was at the "MIN" line and so the guy filled it to the "MAX" line. Yesterday when I stopped it had dropped but not significantly (maybe 2-3mm if that). The strange thing is, I've checked where I've been parked and there is not a single drop of fluid anywhere.
I just had a brake line leak and it's not something you wouldn't notice or just walk by and ignore. Also I didn't once have my brake light kick on during the 2 days of driving it with this leak since I kept the reservoir above min. That's just my experience with mine this past week.
If he does it right he should inspect the rest of lines since he is already there. On mine it ended up being about a 12 foot run of line going to the passenger rear. Not sure why but that line was rusted and ate up with corrosion something awful while the rest were in decent condition.
