Oh NOOOOO! Stripped ignition coil screws
Old Oct 26, 2018 | 01:56 PM
ihaveaquestion's Avatar
2000 C230 Kompressor
Was working to replace the spark plugs on my 2008 C300 Sport this morning. The screws on the ignition coil were very difficult to remove (don't think the previous owner ever bother to replace the spark plugs) and they are made of somewhat soft metal which is very prone to stripping. Anyway, long story short, I've stripped one of them and another one is not looking good either. Could someone please advise on a plausible solution to remove the stripped screw(s)?
A supposed easy job is now turning into a mess.
But even with just two out of 6 replaced, I can feel the engine feels peppier....which is encouraging.
Old Oct 26, 2018 | 04:45 PM
ItalianJoe1's Avatar
2003 CL 600
You rounded the head of the screw off? Use a socket for stripped bolts, they have a twisted design inside that cuts in deeper as you try to loosen the bolt so they grip. Will not be able to re-use those bolts but they will come out that way.
You are using the proper size tool on the coil bolts right?
Old Oct 26, 2018 | 05:27 PM
It's a screw not a bolt. It's is proper size tool but the soft metal does not give confidence when I try to loosen the screw.
Old Oct 27, 2018 | 12:03 AM
2003 CL 600
They are t30 right? You can use a chisel to turn them loose if you know how if they strip, once they are broken loose they should come right out.
Old Oct 29, 2018 | 01:57 PM
Thanks. I got it resolved. What I did is that I bought better T30 driver and applied tons of downward force and quick, impact turn to loosen up the screw. No way I am putting the same screws back in so I am letting two of ignition coils held down by one screw only currently.
Anyone know the correct size for the screw? The width and length? I look up a couple of parts site they don't list it out.
Old Oct 29, 2018 | 02:06 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
most likely M6.
Old Oct 29, 2018 | 02:33 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Part number for the single bolt used to attach the coils on the E-class is A 001-990-72-12. You phrased it in such a way that it sounds as though you have two bolts per coil.
eeuroparts carries the bolts for $1.49 each.
Ebay has them for 99 cents each.
Do a search on Mercedes coil pack screw size.
Old Oct 29, 2018 | 03:17 PM
This?
https://www.ebay.com/itm/1998-2003-M...S!-1:rk:3:pf:1
Hmmm, doesn't look like it. The thread itself may be a fit but the head looks different. Mine is wider and flatter.
Old Oct 30, 2018 | 06:33 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Just so we are clear; it is a bolt. As long as the head seats properly, it doesn't really matter what it looks like. Did you use anti-seize when reinstalling?
Old Oct 30, 2018 | 04:18 PM
It’s a T30 screw. I may take a picture just to convince you
What bothers me is how soft the metal is. Since I don’t expect to ever replace them again so no anti-seize applied. I know one day i may have to eat my own words.
