Swap 4matic to rwd
New to MB so any info would be fantastic even If you haven't done it
E
Also can't imagine it's much more than swapping the trans. There is probably coding for ABS and traction control, maybe just a module swap, idk.
If switching out everything and going to straight to rwd so the rear diff and getting rid of the TC all in all would avoid it
plus I enjoy rwd.
I dont know of what I'm thinking even makes sense or not
sorry
(should of just rwd to begin with)
But is my thinking correct when it comes to getting rid of the TC? Like I said I'm new to MB brand and everything I keep reading is about that particular transmission. So would eliminating that get rid of the worry? I hear the trans part is good but the issue is with the TC and trans together?
I know its considered "1 unit" or is there a issue with that trans as well?
I considered the same thing too but, when it comes to resale or trading in, there might be problems.
I would just fix the transmission once it goes bad. If you are mechanically inclined to swap the 4matic to a rwd, then replacing failed TC bearings should be an easy job.
