Cost for 2013 C350 Timing Chain Replacement
I'm still driving the car and haven't had it repaired. The car's resale value is about $14,000. It's hard for me to justify spending $10,000 on it, especially when it's unclear how long it will go without the repair.
Mine always sounds like that until I give some gas, then it stops. So it sounds like he was right about it. Because apart from that vibrating sound, it sounds perfect. I watched a video on how it should sound when it's good and mine sounds exactly like it apart from that little noise.
The good thing is that I have full warranty from my insurance company, up to 8 years or 150.000 km. If something breaks, engine or the transmission. I'm covered. So I'm hoping that if something will brake, it will break under this period of time.
I'm not sure if it's good that you drive your car around, feels like something might get even worse. Can't you find a cheap mecanic that can work on it on his free time or something?
No other problems with the car I can complain about. Other than regular maintenance, the only work I've done is to replace the radiator last month. Oddly enough, I had to replace the radiator on my son's 2007 Camry the week after I did the Mercedes. After the Mercedes, the Camry was almost fun.
This thread is full of M276 hate - all of it utter nonsense. Mercedes has a terrible track record with almost every engine, especially the early ones. The M271s stretch chains and jump time. The M264s crack pistons. Early M272s chewed sprockets and had intake flap failures. They pretty much all leak oil through wiring harnesses.
The M276 is one of the most reliable modern Benz engines, especially after the first few years. There are very, very few instances of any catastrophic engine issues involving the 276.
I've owned 2 M272 cars and 2 M276 cars: A 2011 C300 and a 2009 E350 with the 272s. A 2014 C350 and 2016 E350 with the 276s. None of them have (or ever did) give me any issues in terms of reliability. However, from a driving/performance standpoint the 276 cars are just vastly superior. From the power they make and the way they deliver it to the fuel economy improvements.. it's a great engine.
EDIT: Sorry, I missed your update. I see now. Still going with the slap for how many more miles, though?
Anyway, the rattle on startup has not gotten worse or better since the diagnosis in May 2019, 26,600 miles ago. The noise varies a lot - sometimes it's barely audible; other times it sounds like the engine will fall apart. Strangely enough, it seems to be louder when the engine is hot. It's still unclear to me exactly what the problem is; I've gotten different explanations.
You know you can read a thousand stories about the rattle, but can you find one where catastrophic engine failure occurred for any reason let alone the timing chain?
I just replaced my crankcase ventilation valve, PVC. $40. If you have high crankcase vacuum it's starving the upper half of oil. Quieter idle from the valve train.
Edit: as for what the problem is it's no doubt the tensioner still losing their oil. Sure the chain might be a little stretched, but the tensioner can obviously do the job once it gets its oil. I would love for someone to experiment with a ratcheting tensioner.
If you've got the check valves back there too already, I've also an occasion guessed that maybe they got gunked up a little and aren't helping as much as they could. I don't suspect it's going to do much more damage than bugger the adjusters again. $100 fix on bank 2 intake sorta thing
Thanks for the reply
Good luck
$11,000+ is an eye watering repair estimate for a 13 year old car. But you’re probably not going to get anything reliable for that or less. The only problem is that if you spend it, you’ve still got a 13 year old car. What goes next, a $10,000 transmission?
i think it’s unlikely that the camshafts are needed. That will also bring down the repair labor considerably. The whole job with aftermarket phasers could maybe be around $5k. Maybe doable if you shop around, but your call.
If you’re really thinking of a new car, the W206 C Class is quite a bit larger than the W204 was.
The check engine light would come on periodically. I didn't see any reason to pursue it since I was pretty sure it was the stretched chain. I'm not sure why the light didn't stay on all the time, but it's not very bright and easy to ignore. In fact, when I got it inspected, the inspector was just finishing up when he noticed the light was on. He almost missed it.
"If you’re really thinking of a new car, the W206 C Class is quite a bit larger than the W204 was." My favorite Mercedes was my 2000 C230 Sport. It was small, quick and fun to drive. This was before the C-Class with those ugly headlights. For me, the C-Class, like so many American cars, unnecessarily bloated over the years.
A tear just recently appeared in the driver's seat. The parking brake broke (repair estimate is $600+). Maybe it is ready for the junkyard. I'll miss those AMG wheels, though!
The CLA is more like the size of the W203 C Class, but it’s electric now. Maybe a 3 year old CPO would be worth looking at.
