M271 Evo engine
Old May 30, 2019 | 02:56 PM
Kdc36's Avatar
95 c36
M271 Evo engine
So some of you know my C250 engine blew up the other day.
so why is the M271 engine such a failure, all you hear is bad things.Is it the design or just bad quality???
Old May 30, 2019 | 04:37 PM
azblk's Avatar
2013 C250 SPORT, 2014 WRX STI SEDAN, 2017 E300 4MATIC
I disagree with your premise that it is a bad engine. I think like everything else there is some defective units and some good units. From your other thread the car warned you - rattling noise, if you had had it checked at that point the chain could have been replaced before the engine failed. That being said there is no reason that a properly maintained car should be having a stretched/broken chain at your mileage.
Old May 30, 2019 | 05:14 PM
Kdc36's Avatar
95 c36
The reason I didn’t really think it’s a big deal with the rattling of the chains is because I had a Volkswagen vr6 and they all rattled a bit. And its not like the chains on the Merc rattled all the time and were really loud.And I did maintain my car the right way.
Old May 30, 2019 | 08:58 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
My M271 in my 2005 C230 is still going strong at 148000 miles, with original timing chain. I’ve used Mobil 1 0W40 since new.
Old May 30, 2019 | 10:01 PM
Cbr944's Avatar
2010 c250 cgi, 2001 Porsche Boxster S
In my view replacement of the timing chain and tensioner should be a service item with a similar interval to a timing belt.
The M271 chain is a single chain which is prone to wear (stretching) before other parts of the engine wear.
The tensioner can also be problematic. Similar designs have been known to cause engine failure in VW/Audi products.
At any sign of rattling at start up, immediate action should be to have both items replaced. This is reasonably easy to do as a new chain can be pulled through by the old one; full teardown isn't needed. The tensioner is accessible from outside the engine.
Old Jan 13, 2023 | 06:52 PM
423859K__8fg's Avatar
2014 slk 250
Is a 2014 slk 250 engine a interference engine 1.8 turbo i believe it is a m271 evo
Old Jan 14, 2023 | 02:01 AM
Russell Ormerod's Avatar
not a merc
Yes
Old Jan 15, 2023 | 08:24 PM
spb147's Avatar
W204 2013 C250 Coupe
from my experience, my c250 m271 engine is absolutely terrible with a plethora of endless problems despite a great maintenance record.
