Real World Amount of Tranny Fluid?
Subscribe
Jun 3, 2019 | 09:36 PM
What are you people doing to get 9+ L into your 722.9 transmission?
I have a 2010 C300 with ~95k and this is the second transmission service Ive done. I didnt write it down but I know I didnt get 9L in it the first time and I only got 8.5L out of it this time(5.1L TC, 3.1L trans) and it only took 7.5L back in. 10L in and then bled off 2.5L at ~113F.
Car was dead cold when I drained it. I had the car in N when I did my initial 10L fill and then I shifted from P to D and back again. Shut it off because the fluid got too hot. Waited for it to cool off (about 2 hours) and then started it. Left it P, heated to 113F and 2.5L came out until trickle.
Is this normal?
Am I too low? Am I going to screw something up?
I followed the WIS EXACTLY.
Reply 0
Jun 4, 2019 | 11:28 AM
That sounds about right. When I did mine, it took in about 8L.
Reply 0
Jun 5, 2019 | 12:37 PM
Thanks for responding. That makes me feel a little better. I was worried I screwed something up (parking brake or not/drained cold instead of hot/etc).
Speaking of which. Does anyone think it makes a difference if the rear wheels are spinning during the initial fill which requires the tranny in N while idling? I had all 4 wheels off the ground so the rear wheels were turning during fill. I have WIS and there is no mention of this. Only that the vehicle has to be in N for fill then P for the bleed off.
Reply 0
Jun 7, 2019 | 06:59 AM
hi
normal the zf pdf say 9.2
if you remove 1.2 liter from torque conveter
narry
Reply 0
Subscribe
Currently Active Users (1)
