W204 drilled brake discs
I have a 2010 C250 CGI Avantgarde, without sport package. I am thinking of replacing the brake discs.
On every website, there is a comment for the brake discs, whether is it produced for cars with, or without sport package.
The drilled discs are meant to build into cars with sport package.
I would like to replace the actual discs for drilled ones.
And the question is: Could it be a problem, if I replace the actual, stock (non-sport) discs for driled (sport) ones? Because basically they are produced for cars witch sport package.
However, the brake pads and calipers on my car will remain the stock, non-sport package brake pads.
Will the drilled brake discs with the standard brake pads and calipers work well? As far as I know, dimensionally they are the same, so there shouldn't be any fitting problem.
I am just afraid about the stock brake pads with the sport brake discs.
Because my brake pads and calipers are designed for the non-sport brake discs.
Thank you for help!
And, also btw, rotors with holes cannot be machined with common brake lathes. Practically, not too big of a loss because rotors today are so close to min spec that you often don't have enough material to turn one anyway.
Enjoy!
English is not my native language, but if I translate "rotor with holes" to my language, it sounds pretty mean
However, thank you for the replies!
I've brought the whole set "drilled and slotted" rotors with ceramic pads on ebay,
The price is much more affordable and also great improved braking power.
Sport is 300mm rear , 295 front !
If you want a real physics ( leverage) improvement beyond any fancy pads or discs find the 322mm set up .
Should have thought to pick-up new center caps...
I just looked at Power Stop's site and for drilled or non-drilled OEM, the Power Stop part numbers do not change.
rotors front & rear all calipers and new lines, I bought stop tech drilled / vented, and ceramic pads.
They are nice I bought the same for my sienna minivan also.
I did buy new stoptech ceramic pads for my c300 but they have not been installed.
i am pretty fanatical about brakes, I don’t play around. I have had very good luck and experiences using OEM pads and Zimmerman rotors. The OEM pads perform very well, they are quiet and grab really good. The akebono pads are ceramic, meaning they perform well when they are hot, but when cold they don’t stop the car the best and I’ve heard people almost getting into accidents because the pads were still cold. Zimmerman is one of the high quality tier manufacturers, they manufacture the OEM rotors for a lot of the Mercedes cars/SUV’s. Their quality is top notch! I really don’t think you will find a better rotor manufacturer for our car. So, I would use the correct Zimmerman rotors (I said there are 2 different brake pkgs), for pads if you are a normal driver I would use OEM pads, if you are a heavy foot(which I am) and stop hard a lot I would consider akebono pads, or still be likely fine with OEM. I prefer OEM sensors as well. It’s vital you have the job done right for everything to last as well.
https://www.rockauto.com/en/catalog/...hub,rotor,1896
Just because a manufacturer splits the parts out by the trim level name does not mean the parts are specific to that trim level only. There is a difference in what came OE. The manufacturers are going to list their parts the same way.
However, just as Power Stop shows their rotors -drilled or not- can be used on any (non C63) trim level. so do other manufacturers.
If you want to know if a trim level has different specs, you have to look at the specs:
https://www.rockauto.com/en/moreinfo...447287&jsn=315
https://www.rockauto.com/en/moreinfo...447287&jsn=314
