c250 rough cold start
Old Apr 18, 2023 | 03:19 AM
calitintz's Avatar
c250
Originally Posted by chinatownabc
my car was there also for about 5 weks or so, did this also happen after the hpfp change? Is your car running lean as well?
Yes. Right after the hpfp replacement.
they replaced the plugs, coil, injectors, fuel pressure sensor in the tank and the fuel rail, another fuel pump and ecm to try and fix the misfire, but nothing changed. Still misfiring.
Old Apr 18, 2023 | 03:23 AM
chinatownabc's Avatar
2005 E55 AMG
Did they charge you for all the replacement like the coils and injectors and etc. I assume its misfiring on all 4 cylinders.
Old Apr 18, 2023 | 03:37 AM
calitintz's Avatar
c250
Did they charge you for all the replacement like the coils and injectors and etc. I assume imisfiring on all 4 cylinders.
Misfire on cyl 3. And sometimes random misfire. I asked them to replace all if they are replacing one thing. Just so all are new at the same time.
Old Apr 18, 2023 | 08:10 PM
2005 E55 AMG
So did you get your car back same thing?
Old Apr 18, 2023 | 09:12 PM
calitintz's Avatar
c250
yeah nothing changed. Still misfiring.
Old Apr 19, 2023 | 12:16 AM
calitintz's Avatar
c250
I might have some promising info for you.
today I got a call from a Indy shop that’s had my car. They said it hasn’t misfired in two days. They will let me know tomorrow what parts they replaced.
Old Apr 19, 2023 | 05:11 PM
  #32
calitintz's Avatar
c250
fixed!
Low pressure fuel pump and fuel filter
running perfectly now.
Old Apr 28, 2023 | 04:08 PM
  #33
2005 E55 AMG
fixed!
Wow awesome ill give that a try thanks so much.
Old Apr 28, 2023 | 04:14 PM
  #34
2005 E55 AMG
fixed!
do you know the exact part number they replaced? Might be on the invoice. im looking online and it seems that it might be the following, be great if you can confirm if they replaced both.
2124701394 (left pump)
2044700294 (right pump)
Old Dec 16, 2024 | 10:27 PM
  #35
Yrv622's Avatar
Solucion de arranque en frío
If you figure out a solution please post.
my car has been at Mercedes for 7 weeks. Master tech and shop foreman has been on it. And they couldn’t figure it out, just got a call today for me to pick up my car, still cold start misfiring
The thing is very simple, under the air filter on the spider or manifold there is a TAF sensor, it is the first one, it has two tabs on the sides, well when the engine is cold, that is, disconnect it... and you will see that the fault disappears...
