Misfire P0301 UNSOLVABLE M271 C230
*Coils
*plugs
*injectors
*fuel pump
*fuel filter
*$12 hose inspected, no leaks
*idler/tensioner/alternator/power steering pump/belt ** (all brand new within the last 2 weeks)**
*supercharger oil filled/changed
*new coolant tank
*full compression test (head is fine, not valves)
*MAF sensor cleaned/inspected
*all fluids changed (oil/transmission/dif)
*all oil cleaned out of inner cooler piping and throttle body (very small amounts)
Now onto the problem.......after replacing all these components, my car is still throwing intermittent P0301 code for cylinder 1 misfire, in which the car shakes violently, sometimes stopping and restarting helps temporarily but the problem always returns.
I love this car,
PLEASE HELP
*Coils
*plugs
*injectors
*fuel pump
*fuel filter
*new coolant tank
I love this car,
PLEASE HELP
Sometimes it will throw a P0304 code.
Dealer thinks it maf but it hasn't thrown a code for the MAF.
No answers from anyone. I may leave it at the dealership over night and have them put their scan tool on it.
It still has its original battery from 2013. Car starts up well no slow cranking but I've heard if the battery doesn't have it's full capacity the electronic doesn't like that. Until the alternator kicks in the battery needs full capacity to keep spark and things up to spec.
Any oil in any of the plug wells when you chanegd them?
I tried moving the coils around but the miss didn't follow the coil. Keep in mind this only happens for 20 or so seconds on cold start up and smooths out when the idle drops to say below 1000 rpm.
Got the car back today, turns out there was a bit of oil in the harness and looking at buying new ECU. Will up when part is received and installed.
Thanks everyone for the tips
-Dezairay
