**Xzero’s M272 & M276 Service Thread**
Thermostat
If you like the thread, please rate it 5 stars and request for it to be stickied.
Thanks!
I have all of the Service Booklets here:
https://mbworld.org/forums/c-class-w...re-thread.html
2013 C-Class with M276 gets spark plugs at 60,000 miles.
Are you saying the car is now showing the need for a Service 12 again at 80,000 miles? Or is there a mistake in my guides somewhere that’s telling you they need replaced?
If it’s the former, my best guess is that the Service wasn’t recorded/saved at 60,000 miles and has popped up again.
If it’s the latter, let me know where so I can remove the info until it can be corrected.
Thanks!
If you're getting a message on the odometer then it was not set correctly.
Mercedes Benz of Raleigh has an index of manuals if you need to download a PDF.
Thanks!
actually, a while back the dealer did a Ecu update, do you guys think maybe that’s it?
I would refer to his 1st post docs.
Thanks!
So I should not have said that it's unlikely. It does happen every once in a while.
They can revert back to the previous.
I would contact the dealer. They should not charge you to take a look.
- Added *** notes for C300/C350 Front Differential Capacity under FLUIDS
- Added specific battery group for Battery and AUX Battery under MISC
