w204 C200K 722.6 Weird Transmission slip in 2ndgear
After searching through this and several other forums, i cannot seem to find the solution to my weird problem. I have a 2007 C200K (W204) with 5-speed automatic (722.6 i believe). Only in second gear, when i give light throttle (30-50%), the car launches fine, but before shifting to 3rd it gives a jerk around 2k rpm, the rpm drops to 1.5k and then rises again to around 2k and then shifts to 3rd. It only happens in the second gear, the rest of the gear shifts are smooth. Happens both in C and S mode. It also happens in Manual shift mode, e.g. if i force the car to keep in the 2nd gear by selecting it manually, it will launch fine, but around 2k rpm i get this slip/jerk and the rpm drops to 1.5k then normally goes upto 6k. I am puzzled what this could be. would be great if anyone can help on this one? I will make a video of this later, but i found another video from someone having same problem(without solution):
Can you get the car scanned with an MB scanner (STAR/DAS/Xentry) and pull the transmission control unit fault codes? These will help us properly diagnose rather than throw parts at the car.
https://www.derpade.de/anleitung-mer...wuek-wechseln/
This is exactly what is happening to my car. so i figure is either the TCC solenoid or if i am super unlucky the complete conductor plate, valve body etc.
I am not sure how sophisticated the Bosch scanner is. If it's a generic OBDII scanner, it cannot read the proprietary MBZ fault codes which give much more information. If access to the workshop and STAR is free, go for it right away. Good luck.
I have the same symptom RPM drop from 1600 to 1500 in 1st gear and drop from 2300 to 2200 in 2nd gear.
the jerk happen in 3 modes (C, M and S)
