Need ​​​​​​​Assistance with MAF replacement on C200 W204 1.8 Ltr Petrol 2012
Old Oct 20, 2020 | 12:05 AM
Anil Sharma's Avatar
C200 W204
Hi Friends , New to the forum.
Old Oct 20, 2020 | 07:36 PM
RA021223's Avatar
I don't believe it has a MAF. It has 2 MAP sensors and 2 Air temp sensors. Each pair for before and after boost. For the turbo model that is. I don't know if it's the same for the Kompressor
Old Oct 20, 2020 | 07:58 PM
C200 W204
Thank You JV , Ive realised that the intake hose (Breather pipe ) was broken at both ends , I was thinking of cleaninf the MAF , as you confirmed that there is no MAF , Can I clean MAP sensors after replacing the breather hose , would appreciate if you could share the Pic/location of these sensors ?
Ive CRC MAF/throttle body cleaners cleaners
e CRC
Old Oct 20, 2020 | 08:47 PM
meazz1's Avatar
C250 2013
The breather pipe is not sold at the dealer. You have to buy the entire assembly.
I bought this from amazon two wks ago to replace the busted pipe.
Air Intake Turbo Tube Turbochagrer Intake Pipe Hose Air Intake Turbo Tube Turbochagrer Intake Pipe Hose
Old Oct 20, 2020 | 09:00 PM
C200 W204
Thank You Meaz, ordered 1
Old Oct 20, 2020 | 09:59 PM
RA021223's Avatar
You can definitely clean the MAP sensors. I used MAF cleaner for the MAPs on other cars I had and it worked fine.. Couple of sprays inside the port should be fine then let dry.
The two red circles show the 1st MAP before the throttle body and the 2nd MAP on the intake manifold. You should be able to see the 2nd MAP by taking off the air filter housing, it should have a blue sticker.
Old Oct 21, 2020 | 06:35 PM
C200 W204
Thank You JV , Shall I ignore the green circle ?
Old Oct 21, 2020 | 08:13 PM
RA021223's Avatar
the green circle is the air temp sensor and the sensor on the intake tube is the boost sensor. Total of 4 sensors that you can check and clean.
just did the job recently while I cleaned the throttle body.
Old Oct 21, 2020 | 08:24 PM
C200 W204
Thank you JV , appreciate your help .
