Rear main seal change 272 engine
Brief overview: its a 2011 c300 4 matic with 3.0 v6. Car is on 4 floor jacks and I need to take motor out. The rear main seal is presumably leaking, its not comming from above and has 113,000 miles. Im replacing oil pan because as others have done I broke the housing on driver side removing cv shaft (lesson learned) so the r.m.s. is purchased along with 11 1 time use bolts and mb rtv. Where is the best place to unbolt trans? I know some say drop the motor and unassembled sub frame but this has to come out top side. If anyone knows where service manuals for this job would be would be helpful. My expertise on mb is minimal but overall mechanic knowledge is good. Tools I have but the info on making sure I get this out and fix then installed correctly. Any and all help greatly appreciated!
GunDriver (11-03-2020)
E55Greasemonkey (12-02-2020)
Has the (breather) that essentially acts as the PCV been replaced? If it is leaking, it will send oil down the back of the block.
Flmrmercedes (10-28-2020)
the mb dealer informed me of this and I watched a video about the butterfly flaps in the intake which get plugged w oil but this isn't the problem.. either its the rms or the gasket. What i need is to know where to disassemble the trans from engine. Im gonna try and leave the front gear box in place until after engine removal.
This is what I am referring to: https://www.fcpeuro.com/products/mer...kit-oem-515810
I feel your pain!
I also broke the oil pan trying to replace drivers front CV axle. Sure wish I would have seen the C clip holding intermediate shaft in. Terrible design having the machined joint exposed to the road elements to get rust welded....
Ouch!
I live in FL and this normally wouldn't happen. They should of had some kind of anti-seize on the shaft. So how did you remove the cv joint from shaft after you broke the housing? I'm planing on putting in a vise and using mapp gas to heat the joint and expand the ring. Then use the slide hammer. I'm sure the mercedes techs know not to do what we did. I will be pulling the motor soon. It does come out topside and you leave the gear box attached until after its out. I could use some torque specs and someone mentioned the WIS. Don't know where this is though.
chassis (11-03-2020)
Received 3,950 Likes
2017 GLE350 4MATIC
If you are removing parts that will not be re-used, an air chisel wreaks marvelous wonders of destruction on rusted or seized parts. It's one of the most effective tools I have. Nothing can withstand it. =)
Garbage
As far as the WIS goes, got mine from emanualonline for about $25
The following 2 users liked this post by GunDriver:
chassis (11-06-2020),
Flmrmercedes (11-10-2020)
So its bottom out then?
I dropped exhaust to make room to remove bolts from tq converter and get to bell housing
No lift. Yet....
I also had oil leaking from rear on both sides. It was running down the block under both cylinder heads. I replaced the vacuum pump O rings, breather assembly and the cam plugs. Seems to have stopped those. Thought for a moment maybe rear main seal but no evidence of that once the oil pan was off.
Unfortunately I do not have a lift. Car is on 4 jack stands, engine lifted with cherry picker still attached to transmission and front axle carrier lowered out with floor jack.
I did find a new 2 post lift for $2k though. Its now on the list...
chassis (11-10-2020),
Flmrmercedes (11-16-2020)
Update!
I was able to get the front drive shaft to turn ny putting in neutral and grabing the rear drive shaft and turning which makes the front shaft turn. Back wheels need to be off ground. Still the heat shield around u joint at gear box needs to be removed and that isn't fun as 2 of 3 bolts are very difficult to get to. Part of the right front exhaust needs to come out, from head to resonator. I finally enlisted the help of a neighbor who is a european mechanic.
chassis (11-17-2020)
Let me know if you have questions
I have wrapped up the work on the front end and moved on to installing adjustable camber bushings in the rear suspension. I've p
ut about 100 miles on the car after oil pan replacement and complete transmission service. Pleasantly surprised I have no leaks from engine, transmission or steering rack
Flmrmercedes (12-02-2020)
Its out, but have i opened pandoras bax?
This is passanger bank under exhaust manifold where black and head mate. I saw this wirey blue green ****. Looks like the antifreeze. Im thinking this engine has a blown head
I clean off the crap to get a better look. The gasket (or sealant, whichever mb uses) looks ripped away slightly.
Driver bank in back has this peice with oil all over it. I already bought the plastic breather for the other side
Part on drivers side
Not sure about the head, I'm definitely no expert. However, your last pic is of the vacuum pump for your brakes. Mine was also leaking oil down the back of the head. I bought this:
$30 for some O rings is a bit steep, but much cheaper than a new pump. I have several hundred miles on it and no leaks so far..
Here is the YT video I followed for how to:
https://youtu.be/d5DyYqXo2_g
Flmrmercedes (12-03-2020)
Engine is in
When putting the new cv joints in the driver side is being uncooperative. The cv has a female which needs to be pushed over the dredded half shaft. I've got it most the way there but would like to compare to another c300 to see how much more I need to push the cv on. My issue is the cv has stopped and this is as far as I can get it on
still about an 1/8 inch of spline showing. I saw another pic. No spline showing so how to get it on further? Torch maybe? Expand the cv housing and push i guess.
2017 GLE350 4MATIC
Can you post more and better focused and lit photos? Does the end of the shaft have a circlip? Typically the shafts engage until they click. Have you been meticulous about all parts being clean? A light oil film also helps with assembly.
My replacememt CV axle looks the same...
The OEM intermediate shaft and CV on the right. Aftermarket from Ebay on the left. Aftermarket pic is as far as I could get them to seat with the clip installed. It is seated and doesn't easily come off. About 1500 miles on it and no issues..
