Help - Missfire C300 3.0L 272
History: I was on my way home from work and got off the freeway. came to a stop and the MIL light came on and the engine felt like it was misfiring.
Checked the codes and had the following: 0600, 0601, 0605, 0606 or P300, P0301, P0305, P0306
This is what I have done so far.
1. Checked fuel pressure - good
2. Checked cylinder compression - 150 +/- 5
3. Checked the MAF sensor - good
Proceeded with the following:
1. Changed the spark plugs
2. Changed the coils
3. Changed all the injectors
4. Changed all of the cam sensors
5. Changed the Crankcase sensor
I still have the same issue. any help would be appreciated.
Also, we assume a lot but since you had that type of work done we can safely assume all error codes were erased and came back?
Related to potential grounding issues are battery issues. While it may seem unlikely, the Aux battery may not be performing as it should even though the voltage reading may be within limits. That would be the only thing more I would try before taking the car in.
Has either battery ever been changed? If so, how long ago? These cars seem to be very temperamental when it comes to batteries and electronics.
And thanks for updating the thread. Wish everyone who posted questions did that.
That “spot” on exhaust valve 3 must have been severe to require a new head. From the description “… only when cold”, I would have thought replacing the valve and dressing the seat would have sufficed.
