100,000 miles
Old Jun 1, 2022 | 10:23 AM
emfren24's Avatar
2016 mercedes benz c300 4matic
100,000 miles
Im about to hit 100,000 miles on my 2016 c300 4matic.. we've always done the oil changes every 5,000 miles but besides that haven't touched it much besides we changed the spark plugs when i first got it in 2019. What should i do to it now besides an oil change?
Old Jun 1, 2022 | 12:17 PM
Gazwould's Avatar
S204 C250 CDI Sport
Interested in what oil you use ?
Old Jun 1, 2022 | 01:02 PM
E55Greasemonkey's Avatar
This place is a joke.
You have a 205, you're in the wrong forum. Keep a close eye on your front driveshaft U-joints.
Old Jun 1, 2022 | 01:19 PM
emfren24's Avatar
i think its called the mobile 1 foreign one?
Old Jun 1, 2022 | 01:22 PM
hyperion667's Avatar
2012 CLS63
You've never done a brake flush, transmission flush, new battery, brake pads/rotors.....nothing but oil? Did you buy this new?
Old Jun 1, 2022 | 01:31 PM
W205C43PFL's Avatar
I think OP stated they got it in 2019... so I assume used...?
Old Jun 1, 2022 | 01:40 PM
emfren24's Avatar
i bought it used in 2019 with 50,000 miles.. but i just ordered new breaks they come in friday so thats why i was wondering what else to do to it coming up?
Old Jun 1, 2022 | 02:56 PM
2012 CLS63
Ah I see.......I misread your first post. Did it come with service records? Yes, there were things to be done, the few I suggested as well as cabin filters too. Have the maintenance
manual?
Old Jun 1, 2022 | 02:58 PM
emfren24's Avatar
manual?
cabin air filter? Ive done that and i would have to look when i get home..
Old Jun 1, 2022 | 05:58 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Should have done a transmission fluid change also
Old Jun 1, 2022 | 09:09 PM
Just204's Avatar
Mercedes w204 4matic sport
There’s a number of things I would do. I just hit my 100k maintenance (im at 92k) and did a laundry list of things as a way of celebrating paying off the car(bought in ‘16). The op should try to look into the maintenance requirements. Im pretty sure they missed some important maintenance items if they mostly did just oil changes. Changing all the fluids would probably be a good idea but definitely late on the transmission service from what I’m thinking.
Old Jun 3, 2022 | 12:03 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
If you will be keeping the car for another 100k miles better do the tranny fluid NOW (do it every 60k), coolant, differentials (front and back. If you have a 4matic the front one will be a pain to do but required if you really want to keep the car for a LONG time), check the mounts (engine and tranny), flush the brakes. GL!
Old Jun 6, 2022 | 02:03 PM
ezzcoke's Avatar
C300
Hi All,
I have a '13 C300 and it has 120K. I am planning to keep it for another year or two. Beside the regular oil change for every 5K, recently I did the trans flush, brake flush, brake pad/rotor. Anything else ? Should I worry about the water pump or subframe?
Tks in advance
Old Jun 6, 2022 | 07:33 PM
2012 CLS63
Originally Posted by ezzcoke
Hi All,
Tks in advance
Why every 5K? Not every 10K?
Old Jun 7, 2022 | 01:46 AM
Gazwould's Avatar
S204 C250 CDI Sport
I did some subframe proofing .
Old Jun 7, 2022 | 09:15 PM
Just204's Avatar
I change mine every 5K as well. I feel 10K is pushing it and doing it every 5K will help the engine last longer. I also change trans fluid every 30k, brake fluid every 2yrs, air/cabin filters every 20k/2yrs, spark plugs every 45k, just did differentials at 92k. Plus non-routine maintenance/repairs.
Old Jul 22, 2022 | 03:43 PM
Runner06's Avatar
C250sport
Differential fluid
i have 165,000 miles never changed as far as I know.
recommend interval and best fluid to use?
Old Jul 22, 2022 | 08:37 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
use this or MB preferred list
Rear diff is every 50-60k
only takes 1quart
more frequent schedule help preserves the bearings from whistling
Old Jul 22, 2022 | 08:53 PM
makiii's Avatar
E400 Wagon; 2010 ML350; 08 CLK350 Cabriolet; 69 SL280
1st - congrats on the 100,000 miles
"You've never done a brake flush, transmission flush, new battery, brake pads/rotors. Nothing but oil?"
I had a 2008 CLK350 Cabrio that I traded when it hit about 110,000 miles - only traded it because I needed a car that could handle some snow
In the 5 years that I owned the car did A & B service when due and that's it. Car was always serviced at the dealer, never flushed anything, never needed brakes, Still had original battery, never had a repair!
Old Jul 22, 2022 | 09:06 PM
(FYI: standard brakes, tranny, coolant flushes are part of A/B schedules)
Old Jul 22, 2022 | 09:07 PM
makiii's Avatar
Thanks, I stand corrected
Old Jul 22, 2022 | 09:48 PM
Runner06's Avatar
C250sport
100,000 miles
Thanks for the rear diff fluid recommendation
