2013 maintenance 165,000 miles
Old Jul 22, 2022 | 03:49 PM
Runner06's Avatar
C250sport
I keep up with oil,filters, spark plugs, coil paks changed out recently.
trans fluid exchange, have not done coolant
i have not done a full brake flush
anything else I should be doing want to pile on more miles
Old Jul 22, 2022 | 07:58 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
maintenance goodies...
Your list plus:
  • timing tensioner
  • serpentine kit
  • brake caliper pins
  • PCV kit
  • cabine filter < most overlooked!
  • Steering flush
  • coolant hoses
  • thermostat
  • water pump
  • upstream Lambda
  • rear differential oil
  • mounts eng/tran
  • lower control arms
Last edited by CaliBenzDriver; Jul 22, 2022 at 08:32 PM. Reason: missed a couple favorites 😊
Old Jul 22, 2022 | 09:46 PM
Runner06's Avatar
C250sport
Maintenance
I have done engine trans mounts, brake pins with brake replacement, factory pads and rotors. The oem went the distance!
have not replaced steering fluid, radiator hoses.
i do canon filter routine as I am always in the. Car and very aware.
need to do rear diff.
water pump and belt have been done and I inspect visually.
Not familiar with Lamba issue can you elaborate please.
thanks for the info I appreciate your input!
Old Jul 22, 2022 | 10:22 PM
lambda life & death
Originally Posted by Runner06
The upstream lambda wide-band "O2" sensor is what the ECU uses to know how your engine combustion is performing.
The ECU keeps varying the injectors timings to deliver a perfect air/gas ratio based on load, temperature etc...
These sensors get contaminated, partialy plugged and give lazy response to change. The outcome is lack of power. Engine runs like it is old.
Most people think the "O2" is good until it gets flagged with an ECU code.... it makes your engine too lean until the internal ceramic heater finally blows open.
Old Jul 23, 2022 | 10:51 AM
Just204's Avatar
Mercedes w204 4matic sport
You don’t say if it’s a 250 or 300. Also the year
Old Jul 23, 2022 | 12:44 PM
Runner06's Avatar
C250sport
165,000
2013 C250 sport
Old Jul 23, 2022 | 12:58 PM
Runner06's Avatar
C250sport
O2 sensor
I do have check engine light on, my mechanic said it could be throttle body?
Exhaust does smell a little rich.
I like the idea of replacing the O2 sensor, inexpensive and
pretty easy to do.
ECU has been replaced too, about 15-18,000 miles ago.
The top end of the motor was redone at approximately 28,000 under warranty.
I also upgraded the plastic turbo tube that runs across the front of the motor with an aluminum model.
Old Jul 25, 2022 | 05:23 AM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
If it was mine I would replaced the cam chain.
Old Jul 25, 2022 | 06:22 AM
Runner06's Avatar
C250sport
Cam chain
would you happen to know the cost to do so? I believe the dealer did do this when I had a failure 28,000 miles. Cost over 3k
how often mileage wise should this be done
thank you
